| cha914 |
Jan 14 2003, 11:52 AM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus ![]() ![]() ![]() Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
Starting friday I will be pulling the suspension off the 914 and
- installing Koni sports all around with the fully adj perches in the rear -new poly bushings all around (from weltmeister...street compound) -turbo tie rod kit -new ball joints ...anyway...this is the last part of the 914 that I haven't pulled off the car yet, so its time. any, tips, hints that you have will be much appreciated. I am going to be doing this with the help of a lift and plenty of tools...so I am hoping to knock this out over the weekend...doable? Thanks, Tony |
| J P Stein |
Jan 14 2003, 02:32 PM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Are those gas shox?
If not, the fronts are a stinker to get back up thru the hole in the strut mount. You will also find your tie rod ends reluctant to let go of the strut. I good tie rod puller is necessary and one of these (IMG:style_emoticons/default/smash.gif) Removing the tie rod from the steering rack is a challenge. I used a monster pair of channel lock pliers. Access is a bitch. Light a fire for the removal of the rubber bushings (a butane/propane torch). Clean the bejesus out of the surfaces that the bushing ride on. .....I mean shiney clean. Don't forget to bleed the brakes...set the venting clearances....yada. Big freakin pipe wrench .....with cheater bar, for ball joint nut removal. Installation of the nut is *supposed* to be done with a torque wrench (165 ft/lbs) and the special tool that fits the nut. There's more..... As to the time frame. If you can work 20 hour days, eat no food , drink no beer, take no breaks, encounter no problems, take no time to pee (remember, no beer), have all the right tools close at hand, keep off the effin puter, AND make all the right moves....sure, peice of cake. First time for the suspenders, eh? |
cha914 Its Suspension Time! Jan 14 2003, 11:52 AM
Bleyseng Brad is having a class this saturday on front susp... Jan 14 2003, 02:24 PM
cha914 Unfortunately the drive to CA and back from TX wou... Jan 14 2003, 03:06 PM
Jeroen How the fuck do you get the friggin struts off the... Jan 14 2003, 03:37 PM
bhfast ball joint seperator it looks like a big fork, but... Jan 14 2003, 03:48 PM
bhfast local auto parts store should have it for around ... Jan 14 2003, 03:49 PM
J P Stein I didn't mean to sound rude.
I take a much mor... Jan 14 2003, 03:52 PM
Jeroen I got that one... won't work on the strut/ball... Jan 14 2003, 03:53 PM
bhfast when i did mine it didjn't work either, so i u... Jan 14 2003, 03:58 PM
Brad Roberts Here is how to get the ball joint out of the strut... Jan 14 2003, 04:31 PM
cha914 I didn't take anything as rude...just want to ... Jan 14 2003, 04:33 PM
Bleyseng Yeah, the ball joints get rusted in place to the s... Jan 14 2003, 04:37 PM
Brad Roberts Tony.
With proper tools.. I takes me 8 hours to c... Jan 14 2003, 04:38 PM
Brad Roberts I dont use heat.. ever. Your lower ball joints don... Jan 14 2003, 04:40 PM
cha914 ok...thats good info...I will plan on at least dou... Jan 14 2003, 04:56 PM
Bleyseng Well if you use too friggin much heat! Just a ... Jan 14 2003, 05:14 PM
Brad Roberts I tried to take pics of it... but none of them tur... Jan 14 2003, 05:24 PM
cha914 Ok...I have a little dremel...
how deep of a cut.... Jan 14 2003, 05:30 PM
Brad Roberts Umm.. half the thickness of a No.2 Pencil (the yel... Jan 14 2003, 05:33 PM
cha914 sorry, I got confused...when you said thickness, I... Jan 14 2003, 05:55 PM
Mueller Back in the old days when I ran poly bushings inst... Jan 14 2003, 06:12 PM
Bleyseng Nice pic! Thanks, you sell those too??
Geoff :... Jan 14 2003, 07:41 PM
Brad Roberts Mike would whore his ass out if he had too.
:sho... Jan 14 2003, 07:44 PM
cha914 hang in there mike...maybe in a year I will be giv... Jan 14 2003, 09:13 PM
Gint This is what it looks like when you get it all out... Jan 14 2003, 11:08 PM
cha914 That looks real nice ginter...but mine are going t... Jan 15 2003, 12:21 AM
Jeroen wow! nice clean up!
did you have all that ... Jan 15 2003, 02:57 AM
Gint I bead blasted it and powder coated it all right i... Jan 15 2003, 10:32 AM
gklinger ![]() ![]() |
Lo-Fi Version | Time is now: 25th November 2026 - 10:52 PM |
