| mrholland2 |
Dec 10 2011, 01:23 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 761 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Okay, a newish noise has begun. It actually started a while back but only when making pretty aggressive turns. Tonight, very cold, the noise happened just driving straight.
It is coming from behind me and low, a bit left. It is a light thunk thunk thunk and is the same speed as the yet to be fixed pulsing front brakes. .but is unrelated because it is from behind me. It slows down and speeds up with the speed of the car, unrelated to engine speed. CV joint? Something loose where the axle half connects to the transmission? Maybe? (IMG:style_emoticons/default/headbang.gif) Thanks Sean |
| stugray |
Dec 10 2011, 12:03 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
sounds like a CV joint.
And my attitude towards the HOA is to just do the work anyway. you dont have a garage or carport? If you knew which CV, it can be replaced in about 30 minutes. Stu |
| mrholland2 |
Dec 10 2011, 12:21 PM
No garage or carport. . townhouses circa 1980. . lakefront, and remember, I'm on the board. . I would have to issue a 100 buck fine to myself. Without this rule, we'd have cars on blocks. . engines in parking spaces etc. .
It seems like a GENTLE drive to my friends would be okay?????? sounds like a CV joint. And my attitude towards the HOA is to just do the work anyway. you dont have a garage or carport? If you knew which CV, it can be replaced in about 30 minutes. Stu |
| Spoke |
Dec 10 2011, 01:11 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,438 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
It seems like a GENTLE drive to my friends would be okay?????? Only you can answer that question. How bad it is. How long until it explodes or comes apart. You could always do the ghetto thing and take it to a nearby strip mall, go behind the mall and out of the way and jack it up there. If someone (police) questions you just explain you may have a major issue and the car may need towed. You are just inspecting for trouble. |
| mrholland2 |
Dec 10 2011, 04:07 PM
It seems like a GENTLE drive to my friends would be okay?????? Only you can answer that question. How bad it is. How long until it explodes or comes apart. You could always do the ghetto thing and take it to a nearby strip mall, go behind the mall and out of the way and jack it up there. If someone (police) questions you just explain you may have a major issue and the car may need towed. You are just inspecting for trouble. The nearest strip mall is 25 miles away as well. (IMG:style_emoticons/default/smile.gif) |
mrholland2 Strange Noise Dec 10 2011, 01:23 AM
RobW The rear main drive shaft may be detaching. Your c... Dec 10 2011, 06:27 AM
mrholland2 It is against the rules of my HOA (I'm on the ... Dec 10 2011, 10:26 AM
Als914
It is against the rules of my HOA (I'm on the... Dec 10 2011, 01:37 PM
pcar916 100% inspection under the car of every nut and bol... Dec 10 2011, 09:11 AM
underthetire A hoa :shoot2kill: and your on the board with a 9... Dec 10 2011, 11:55 AM
somd914
No garage or carport. . townhouses circa 1980. . ... Dec 10 2011, 01:07 PM
mrholland2 I imagine I can get away with some checking. Hone... Dec 10 2011, 04:12 PM
Ductech I love the bull shit involved with HOA and trying ... Dec 10 2011, 02:01 PM
vsg914 Unless your very large chested, you should be able... Dec 10 2011, 02:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th November 2026 - 05:12 AM |
