| david63 |
Dec 16 2011, 07:23 AM
Member ![]() ![]() Group: Members Posts: 98 Joined: 9-August 09 From: Parker Colorado Member No.: 10,653 Region Association: Rocky Mountains |
It will become obvious that I am not the best mechanic in the world so keep that in mind when you hear my questions.
My 1970 914-6 (GT replica w/ twin plug 2.5) is not feeling too well. A job change kept me away from the car for several months and now you guessed it - it will not run. What have I done so far... I suspect that the gas is bad so I drained the gas from the tank, replaced it with new gas (even put in a couple of gallons of high octane racing fuel (I know the fuel is OK now). What the car is doing... It will start if I put a little gas in each carb (has 40 MM PMO's) it starts right up and NOW if I keep my foot in it I can keep it running. It will not idle and it does not hold a constant RPM with no change in throttle position? I think the fuel psi could be the issue or there is something wrong with the carbs(different settings on the regulator between 3 psi and 9 psi do not seem to help or hurt)? Could the PMO's be plugged with crap (when I left the car sitting I ran it out of fuel prior to storing the car). Maybe the factory fuel pump is going bad. The car was set up like the GT with the factory fuel pump moved up front. Car ran fine before storage (actually would flood really easily prior to the storage period). Does someone rebuild the factory pumps as I have an extra that is leaking badly and thought I might re-build it and try that but would rather not just "swap parts". Any thoughts, Thanks. |
| david63 |
Dec 16 2011, 01:27 PM
Happy happy joy joy... worked the linkage and had only one working (five not working). Pulled them all and found most plugged with crap? Replaced fuel filter (did not appear to be bad but not expensive).
After cleaning all the idle jets jumped in the car and cranked it up. It ran fantastic, idled fine. WOW. Very cool. Let the car warm up, aired up the tires and drove it for the first time in almost a year. What a drag having to leave the car sitting. My job will pull me away in a few weeks. I have 2 gallons of 112 octane racing fuel mixed with 2 gallons of 91 octane (w/ some 5 or 10% freakin ethanol) for a total of 4 gallons in the tank. Ideas on what to do with this fuel.? The guy at the fuel place said the VP C12 does not break down like the new gas does but still wondering if I should drain all the fuel out before I leave again? Is pulling the fuse on the pump and running the carbs out of fuel OK as well? Thanks for all the great advice and input. |
david63 What's wrong with the fuel system? Dec 16 2011, 07:23 AM
GeorgeRud Plugged idle jets? Today's fuels do break dow... Dec 16 2011, 07:27 AM
914Sixer Worst case is the fuel sock filter in the tank is ... Dec 16 2011, 07:33 AM
scotty If your PMO's have screw on fuel filters, they... Dec 16 2011, 08:14 AM
naro914 If it runs and just won't idle, it's proba... Dec 16 2011, 08:22 AM
david63 Thanks for all the quick responses.
I will chec... Dec 16 2011, 08:33 AM
naro914 If you pump the gas a few times before trying to s... Dec 16 2011, 08:40 AM
david63 Interesting question. A couple of times it did st... Dec 16 2011, 09:00 AM
pcar916 Back to basics. Check that your fuel pump is work... Dec 16 2011, 09:38 AM
J P Stein Starting a carbed car, after it has sat for a mont... Dec 16 2011, 11:20 AM
naro914
Hand operating the linkage while looking down the... Dec 16 2011, 11:24 AM
J P Stein
Happy happy joy joy... worked the linkage and ha... Dec 16 2011, 01:40 PM
naro914 you may want to try this: run a bunch fuel system ... Dec 16 2011, 02:08 PM
shoguneagle When you leave to go back to your job get a produ... Dec 16 2011, 03:01 PM
campbellcj FWIW my car regularly sits for 2-6 weeks between u... Dec 17 2011, 01:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 09:44 AM |
