| partwerks |
Dec 12 2011, 02:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,642 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
First, does anyone know the size of the nut that goes on where you adjust the terry cable back by the clutch fork, as my mechanic lost/forgot to put the second nut back on and I plan on getting another one at Ace, but don't recall what size it is.
I put on that delrin pulley on back, but also was wondering if that bolt should also be replaced as maybe it has some wear with a bit of play in it as well?? I adjusted the cable and when the clutch grabs, the pedal is about 2" off the floor board. Is that about the correct distance. If not, do I need to tighten it or loosen it? After waiting about 5 seconds to put in reverse, it does not grind into gear. Is that any indication? |
| partwerks |
Dec 18 2011, 04:30 PM
I slithered under the car and put the 7mm nyloc nut on this afternoon.
I didn't have any problems finding that size at Ace Hardware. I could also get them in wing nuts, acorn nuts, etc. .46 cents worth. Wish everything was that cheap on this car...... |
partwerks clutch cable Dec 12 2011, 02:23 PM
RonnieJ Bump Dec 12 2011, 04:48 PM
GeorgeRud On the cable I have, it's a 7mm nut. I always... Dec 12 2011, 04:57 PM
bigkensteele I thought that it was 8mm, but I could be wrong.
... Dec 12 2011, 05:37 PM
dlee6204 The nut should be 7mm. Dec 12 2011, 05:54 PM
Drums66 ......I'll join in 7MM :idea:
:wavebye: Dec 12 2011, 06:34 PM
partwerks Once the snow dries off and I can take it for a dr... Dec 12 2011, 07:45 PM
bigkensteele
Once the snow dries off and I can take it for a d... Dec 12 2011, 07:56 PM
914.SBC I had a hard time finding a 7mm. If you dont have... Dec 12 2011, 08:34 PM
partwerks The nut in front is not a Ny-loc, but the outer on... Dec 12 2011, 08:43 PM
bigkensteele
The nut in front is not a Ny-loc, but the outer o... Dec 12 2011, 08:50 PM
Dave_Darling Double-nutting is more than sufficient. In fact, ... Dec 13 2011, 10:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 08:55 AM |
