| PeeGreen 914 |
Dec 18 2011, 08:11 PM
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest
So many months back I made a trade for some custom wheels. Well, they are all done and I have them (IMG:style_emoticons/default/piratenanner.gif)
I painted the centers and weighed them. They came in at 13.5lbs. What does a 5 lug Fuchs weigh? Attached image(s)
| 76-914 |
Dec 19 2011, 10:21 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
So this is 1.5lbs heavier than a 5-lug Fuchs (IMG:style_emoticons/default/smile.gif) Tires that will be mounted are 225 45 RA1s and 3.5 lb's heavier than Dan Gurney AKA American Racing Jon Where those polished and who did the polish? I've been sanding on mine and that is alot of work. (IMG:style_emoticons/default/santa_smiley.gif) It's actually pretty easy. If you want to do the part of the rim where the stem is you will have to dismount the tire. Otherwise, just jack up one rear wheel (chock the front ones for safety) then start the engine and put it in 2nd gear. While the tire is spinning place the "wet sandpaper" over the area you desire to polish, working from 1200 grit thru 2000 grit. Follow up with polishing compound and then a finish compound. You will need a rubber backed sanding pad to hold the sandpaper in place or you will toast your finger tips as all this friction will = heat. I see that I've got a set that I'm just trying to do the rim then I'll paint just the centers like Panasports silver wheel paint. (IMG:style_emoticons/default/santa_smiley.gif) Yours do look great! next time we meet you'll have to tell me how much you have in them without the wife finding out. Paint the rims first then follow above instructions. Takes about 10 min's per rim. ![]() ![]() |
| 7TPorsh |
Dec 19 2011, 12:26 PM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
So this is 1.5lbs heavier than a 5-lug Fuchs (IMG:style_emoticons/default/smile.gif) Tires that will be mounted are 225 45 RA1s and 3.5 lb's heavier than Dan Gurney AKA American Racing Jon Where those polished and who did the polish? I've been sanding on mine and that is alot of work. (IMG:style_emoticons/default/santa_smiley.gif) It's actually pretty easy. If you want to do the part of the rim where the stem is you will have to dismount the tire. Otherwise, just jack up one rear wheel (chock the front ones for safety) then start the engine and put it in 2nd gear. While the tire is spinning place the "wet sandpaper" over the area you desire to polish, working from 1200 grit thru 2000 grit. Follow up with polishing compound and then a finish compound. You will need a rubber backed sanding pad to hold the sandpaper in place or you will toast your finger tips as all this friction will = heat. I see that I've got a set that I'm just trying to do the rim then I'll paint just the centers like Panasports silver wheel paint. (IMG:style_emoticons/default/santa_smiley.gif) Yours do look great! next time we meet you'll have to tell me how much you have in them without the wife finding out. Paint the rims first then follow above instructions. Takes about 10 min's per rim. ![]() ![]() Hmmm. I never would have thought of using the car itself as a lathe. |
| zymurgist |
Dec 19 2011, 12:30 PM
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Hmmm. I never would have thought of using the car itself as a lathe. I would not try this at home. A motorcycle forum I hang out on has stories of how people used a similar method to clean their motorcycle chain, which usually ends up with fingers getting cut off. Apples and oranges, I know, but running a vehicle in gear with no one at the throttle looks like an accident waiting to happen IMO. |
PeeGreen 914 What weighs 13.5lbs, is for a 4-lug car, and is a 15x7 wheel? Dec 18 2011, 08:11 PM
scott_in_nh Sweet!
More details and closer pictures please... Dec 18 2011, 08:21 PM
Krieger :drooley: :drooley: :drooley: :drooley: WOW... Dec 18 2011, 08:21 PM
smontanaro I Googled for Porsche wheel weights and came up wi... Dec 18 2011, 08:29 PM
PeeGreen 914 So this is 1.5lbs heavier than a 5-lug Fuchs :) T... Dec 18 2011, 08:47 PM
NORD Jon
Where those polished and who did the polish? ... Dec 18 2011, 08:59 PM
PeeGreen 914 They are Mahle centers but polished aluminium hoop... Dec 18 2011, 09:01 PM
NORD I see that
I've got a set that I'm just t... Dec 18 2011, 09:07 PM
PeeGreen 914
I see that
I've got a set that I'm just ... Dec 18 2011, 09:10 PM
Socalandy :drooley: very nice!!! Dec 18 2011, 09:14 PM
rick 918-S 16" X 7"
Dec 18 2011, 09:58 PM
jcambo7 Dang! 140 lbs? :poke: Dec 18 2011, 10:41 PM
audio_file Those are gorgeous! Dec 18 2011, 10:53 PM
smontanaro I'm sure I'm being dense here, but I thoug... Dec 19 2011, 05:16 AM
PeeGreen 914 I'm not sure how it is done but basically just... Dec 19 2011, 09:55 AM
PeeGreen 914
and 3.5 lb's heavier than Dan Gurney AKA Ame... Dec 19 2011, 12:17 PM
76-914
and 3.5 lb's heavier than Dan Gurney AKA Am... Dec 19 2011, 04:01 PM
PeeGreen 914
[quote name='PeeGreen 914' post='1591385' date='D... Dec 19 2011, 04:07 PM
vsg914
and 3.5 lb's heavier than Dan Gurney AKA Am... Jul 3 2012, 08:01 AM
charliew I polished and sanded the empi style wheels on my ... Dec 19 2011, 10:35 AM
rdauenhauer the Gurney / American Racing wheels are 5.5 wide n... Dec 19 2011, 10:44 AM
eric9144 Those look amazing! Sign me up, would love to... Dec 19 2011, 01:08 PM
aircooledtechguy :drooley: Those are absolutely incredible!... Dec 19 2011, 07:12 PM
PeeGreen 914 Done locally. :)
They look really good with 225 ... Dec 19 2011, 08:42 PM
KaptKaos
So many months back I made a trade for some custo... Dec 19 2011, 09:30 PM
championgt1 Those are very nice! :drooley: Dec 19 2011, 09:33 PM
PeeGreen 914 So it looks like I will need to pull the fenders v... Dec 19 2011, 10:26 PM
brant
So it looks like I will need to pull the fenders ... Dec 20 2011, 01:37 PM
bigkensteele
So it looks like I will need to pull the fenders ... Dec 20 2011, 05:55 PM
mwyatt Does anyone know who can make these wheels? I wou... Dec 20 2011, 01:19 PM
PeeGreen 914 I know who made them. Dec 20 2011, 01:36 PM
PeeGreen 914 It's not THAT nice :) Besides, it's now a... Dec 20 2011, 01:39 PM
messix That shot shows prolly the best paint on the car... Dec 20 2011, 03:00 PM
PeeGreen 914 I'm compensating for something :blink: Dec 20 2011, 07:55 PM
Gint Those look great. I wonder why the builder didn... Dec 20 2011, 10:52 PM
championgt1 Jon, is this car going to be ready for this upcomi... Dec 20 2011, 10:53 PM
PeeGreen 914
Jon, is this car going to be ready for this upcom... Dec 21 2011, 12:36 AM
sixnotfour thats a big ass tire;
P225/45ZR15 E 9.0" 2... Dec 21 2011, 12:24 AM
PeeGreen 914
Those look great. I wonder why the builder didn... Dec 21 2011, 12:34 AM
sixnotfour Jon likes big lips. Dec 21 2011, 12:42 AM
PeeGreen 914
Jon likes big lips.
:lol4: :lol: :blink: so? Dec 21 2011, 01:07 AM
effutuo101 Those are sweet! Dec 21 2011, 12:47 AM
Ductech Jon those came out just plain amazing! Makes m... Dec 21 2011, 06:21 PM
PeeGreen 914 Just walked by the car tonight and thought I'd... Jul 2 2012, 10:51 PM
RobW
I Googled for Porsche wheel weights and came up w... Jul 3 2012, 07:44 AM
ConeDodger
[quote name='smontanaro' post='1591097' date='Dec... Jul 3 2012, 10:30 AM
jmill :wub: Beautiful. If I went with a narrow body I... Jul 3 2012, 08:14 AM
PeeGreen 914
:wub: Beautiful. If I went with a narrow body I... Jul 3 2012, 09:44 AM
ConeDodger Oh, I'm sorry Rob. I bet you meant 4 lug Fuchs... Jul 3 2012, 10:32 AM
Oh, I'm sorry Rob. I bet you meant 4 lug Fuch... Jul 3 2012, 11:31 AM
RobW Nice rims. Do you know Harvey pretty well? I have ... Jul 3 2012, 11:09 AM
sixnotfour To increase the width of 4 lug wheels it is cost ... Jul 3 2012, 09:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:55 PM |
