aluminum calipers vrs. iron calipers????, would aluminum calipers be better??? |
Mueller |
May 6 2004, 12:12 PM
With everything being equal (piston size, pad size, rotor...etc....)
Would there be a performance difference between the two setups besides the obvious weight difference? I'm thinking at normal temps, both would be equal. I'm also guessing that once one gets more aggressive with the brakes, the aluminum calipers would be better and would be less susceptible to brake fade due to the better heat dissipation of the aluminum. |
Dave_Darling |
May 6 2004, 12:26 PM
The aluminum is lighter, but it flexes more. I haven't read of the heat dissipation of aluminum being better for braking than iron or steel--the two points everyone seems to focus on are the weight and the flexing.
--DD |
Lo-Fi Version | Time is now: 10th June 2024 - 06:04 AM |
