| 914Bryan |
Dec 26 2011, 05:18 PM
Member ![]() ![]() Group: Members Posts: 190 Joined: 6-June 11 From: Orange County Member No.: 13,162 Region Association: Southern California |
OK, not directly a 914 problem; Thankfully, my 914 is running fine. (IMG:style_emoticons/default/biggrin.gif)
Can't say the same for my 2005 F150 that decided to fire a spark plug from the #3 cylinder hole. (IMG:style_emoticons/default/mad.gif) Heard a ticking sound that progressively became louder then, kaaPow!. Fired that sucker right out of the threads. Broke the coil and split the spark plug. WOW. I would like to say that this was unique, but the same thing happened to another cylinder about a year ago. Helicoil solved it. This is getting stupid. Anyone else have this type of problem? Wonder if Ford had a recall regarding this. Only 85K on the engine...Fix and sell? (IMG:style_emoticons/default/smash.gif) Found On Road Dead? (IMG:style_emoticons/default/screwy.gif) |
| jimkelly |
Dec 27 2011, 01:54 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
steel plugs in aluminum heads = problem waiting to happen.
i guess if plugs are replaced often enough & anti seize is used - problem could be avoided? i like cast iron and steel : ) seems many newer high mileage cars are gonna have a cert in them. my suby has one, my festiva had one. they should cert them from the factory. |
| stewteral |
Dec 27 2011, 03:14 PM
Old Member ![]() ![]() Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
steel plugs in aluminum heads = problem waiting to happen. i guess if plugs are replaced often enough & anti seize is used - problem could be avoided? i like cast iron and steel : ) seems many newer high mileage cars are gonna have a cert in them. my suby has one, my festiva had one. they should cert them from the factory. Hey Jim, It's a great advice using anti-sieze on plugs. I'm sure you meant COPPER ANTI-SEIZE (made for this purpose) as the usual silver stuff will INSULATE the plug from transferring heat to the head, overheat it and cause detonation. Best, Terry |
914Bryan Spark Plug Fired From The Hole Dec 26 2011, 05:18 PM
Steve Google is your friend. I had the same problem wit... Dec 26 2011, 05:39 PM
mrbubblehead that must be the reason time sert make a tool spec... Dec 26 2011, 07:14 PM
76-914 google Time cert. They have a video of how to inst... Dec 26 2011, 08:10 PM
mrbubblehead sert with an "S" Dec 27 2011, 12:17 PM
zymurgist Unfortunately, this is a known problem with Ford e... Dec 27 2011, 02:03 PM
Jake Raby Why do so many people on this board have issues wi... Dec 27 2011, 02:04 PM
matthepcat A buddy of mine did the same thing on his 90's... Dec 27 2011, 02:21 PM
stugray I had this happen on the way to the airport in my ... Dec 27 2011, 02:30 PM
zymurgist I would be willing to bet that somewhere along the... Dec 27 2011, 03:02 PM
Steve I read that the problem is actually not enough thr... Dec 27 2011, 03:15 PM
stewteral
I read that the problem is actually not enough th... Dec 27 2011, 07:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 12:21 PM |
