| DRPHIL914 |
Dec 27 2011, 12:21 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
I have new A/F meter from Summit racing ,
my car is a 75 2.0 d-jet that has SSHE and a Triad dual exhaust 1. where do i put the O2sensor - where to have the guys weld it 2. i think the electrical hook-up is pretty easy, but if anyone has done this and has suggestions or advice before i proceed, please do so!!! Thanks Phil |
| Cevan |
Dec 28 2011, 02:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I've had my LC-1 installed for two years after I built my carbed 2056. I mounted the bung just after the collector on my Bursch exhaust. The unit itself is installed underneath the car in the back right side. The harness goes through one of the grommets in the rear engine tin into the engine bay. That's where I mounted the LED and reset switch. I've got the gauge mounted next to the center console. No issues to report so far. Works everytime.
| mrbubblehead |
Dec 28 2011, 09:18 PM
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
I've had my LC-1 installed for two years after I built my carbed 2056. I mounted the bung just after the collector on my Bursch exhaust. The unit itself is installed underneath the car in the back right side. The harness goes through one of the grommets in the rear engine tin into the engine bay. That's where I mounted the LED and reset switch. I've got the gauge mounted next to the center console. No issues to report so far. Works everytime. no kidding...... dang i had nothing but problems with mine. i had to build a heat sink to no avail. swapped o2 sensors from with my lm-2, updated the firmware.i tried everything and kept getting the error code. my last resort was the delay circuit. if that didnt work i was gonna yank it. because it was useless. you must have gotten a good lc-1 (IMG:style_emoticons/default/drunk.gif) |
Philip W. A/F meter installation and Bosch O2 sensor location Dec 27 2011, 12:21 PM
SLITS Since the experts are not replying .... here's... Dec 27 2011, 05:39 PM
ConeDodger I don't know your system but what Slits just s... Dec 27 2011, 06:18 PM
mrbubblehead i put mine right after the collector. where all 4 ... Dec 27 2011, 07:55 PM
kg6dxn The WB sensor is heated. It does not need to go cl... Dec 27 2011, 09:56 PM
Philip W.
The WB sensor is heated. It does not need to go c... Dec 27 2011, 10:09 PM
Philip W. Here is a picture of the gauge. $200. Dec 27 2011, 10:17 PM
mrbubblehead OH YA! youll be real happy with that. i had to... Dec 27 2011, 10:47 PM
Philip W.
OH YA! youll be real happy with that. i had t... Dec 28 2011, 08:58 AM
SUNAB914 What are you doing Phil? Dec 28 2011, 07:36 AM
mrbubblehead no, your wideband does have a built in heater. i a... Dec 28 2011, 09:57 AM
brant I've been running that gauge since 2006 with n... Dec 28 2011, 10:47 AM
Scott Schroeder
I've been running that gauge since 2006 with ... Dec 28 2011, 12:04 PM
brant
I've been running that gauge since 2006 with... Dec 28 2011, 01:50 PM
sean_v8_914 sensor must be between 9 o clock to 3 o clock (nev... Dec 28 2011, 11:38 AM
sean_v8_914 ps. the software is easy to use and free download ... Dec 28 2011, 11:41 AM
michael7810 I ordered the same gauge from Innovate yesterday p... Dec 28 2011, 11:58 AM
infraredcalvin You really want a system that datalogs if you want... Dec 28 2011, 09:03 PM
mrbubblehead
You really want a system that datalogs if you wan... Dec 28 2011, 09:28 PM
michael7810 The MTX-L gauge has the capability to output a dat... Dec 28 2011, 11:27 PM
sean_v8_914 very nice. its like it has a built in LC-1
• Th... Dec 29 2011, 09:24 AM
Philip W. Sean,
thats what i thought, i says in the manual... Dec 29 2011, 09:57 AM
Steve Sorry for the hijack, but how is this one differen... Dec 29 2011, 10:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th November 2026 - 02:49 AM |
