| underdog |
Dec 29 2011, 09:26 AM
Member ![]() ![]() Group: Members Posts: 82 Joined: 20-September 11 From: Mountain Home, AR Member No.: 13,579 Region Association: None |
I need to replace pedal board. WOOD OR ALUMINUM?
| dlestep |
Dec 29 2011, 07:06 PM
I am smilin'... ![]() ![]() ![]() Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
Aluminum will not absorb water, whether you have carpet or not.
De-populate the pedal board and take it to a lazer cutter and have them replicate it in aluminum with the correct perimeter, mounting holes and slots, and pedal cutouts. I defined the laser tool path in Solidworks and sent it to the shop to be cut and clear anodized. I used a 1/8 inch thick strip of solid rubber sheet (1 x 12 in., on left side and a smaller piece on the center hump. I mounted a new billet throttle stop base and new white Delrin stop screw. (for the moment, I forgot where I purchased it, but I will continue to look, and pass it on.) |
underdog pedal board Dec 29 2011, 09:26 AM
infraredcalvin Are you going to cover it up with carpet? If so j... Dec 29 2011, 09:31 AM
ww914 I agree, if you are going to re-carpet, just use t... Dec 29 2011, 09:45 AM
TurbOH Brad
... Dec 29 2011, 12:53 PM
TurbOH Brad That looks great. Do you still have the Solidwork... Dec 30 2011, 09:16 AM
dlestep I have to look on my old computer, the pedal board... Dec 30 2011, 12:32 PM
underthetire I had an aluminum one fall off the waterjet :D Dec 30 2011, 01:45 PM
ConeDodger Jeff,
With your skill set I would just make one o... Dec 30 2011, 10:09 PM
cwpeden How does Aluminum improve performance while drivin... Dec 31 2011, 03:22 AM
dlestep
How does Aluminum improve performance while drivi... Dec 31 2011, 09:47 AM
ConeDodger
How does Aluminum improve performance while drivi... Dec 31 2011, 02:55 PM
rohar I hate wood, but I'm a CSOB. Grabbed a couple... Dec 31 2011, 10:01 AM
Harpo I just ordered a new aluminum one from renline. I... Dec 31 2011, 05:00 PM
underdog Engman's site says aluminum is not available r... Jan 1 2012, 10:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 22nd July 2026 - 04:29 AM |
