| DRPHIL914 |
Dec 30 2011, 11:01 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,949 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
I pulled the tank to get at fresh air blower., put it all bak together, so I ran down to the station to fill up. Had about a gallon and a half in the tank. Went to take the gas cap off, and there was a lot of suction on there. I only drove about10 miles to the station. And it's noit hot out. This is a 75 2.0 with d-jet. The only thing I can think of is that when I put the tank back in the vapor line got pinched .. is it possible this caused the negative pressure that fast. ? And if so can I just leave it disconnect the expansion tank until the tank level is low enough to lift ip to move the vapor line. ?
Phil |
| Bob L. |
Dec 31 2011, 07:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Don't mean to hijack, just seems relevant...
Mine was converted to a carb (yes, singular) by PO. He plugged the return fuel line. So, basically there is just the fuel line out. Is this going to be a problem? Is my tank going to crush?!?! |
Philip W. pressure in gas tank- went to fill up- just put tank back in, Dec 30 2011, 11:01 PM
kg6dxn I crushed a tank once (not in a 914). The vent/vap... Dec 31 2011, 01:39 AM
76-914 pull the cover from below (4 bolts) and you might ... Dec 31 2011, 10:28 AM
Elliot Cannon
... Dec 31 2011, 07:48 PM
Bob L.
Don't mean to hijack, just seems relevant...... Dec 31 2011, 08:23 PM
BMITCHELL It still should be vented. Vent line on expansion... Dec 31 2011, 07:48 PM
Racing916 I race my 914 with a 6 cylinder and the return cap... Dec 31 2011, 08:47 PM
rgalla9146
I race my 914 with a 6 cylinder and the return ca... Jan 1 2012, 08:26 AM
Philip W.
I race my 914 with a 6 cylinder and the return c... Jan 1 2012, 10:00 AM
kg6dxn Never seen a charcol filter clogged but anything i... Jan 1 2012, 11:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 19th June 2026 - 09:50 AM |
