> bearing inspection, how do these look?
Cool914
post Nov 21 2011, 11:14 AM
Taking apart a fresh rebuilt 2.0 and i noticed the heads qere on wrong side. The one with the head temp sensor spot was on 1,2cylinder side. possible reasons, problems?
Cool914
post Jan 2 2012, 11:14 PM
I don't have any history on the engine, was told when I bought it that it was rebuilt recently, but looks like it was probably just "pressure washed and painted". (IMG:style_emoticons/default/sheeplove.gif)
I will be replacing the clutch disc obviously, I was just asking about the pressure plate since it didnt look bad at first glance.
Yes, I will try an electron microscope photo next time for SirAndy.
Anyone have any comments on the hammering of the bearing number transfer onto the case bearing surface?
malcolm2
post Jan 3 2012, 10:54 AM
QUOTE(Cool914 @ Jan 2 2012, 11:14 PM) *
I went thru the same type questions about my case. "Do I need to Align Bore, should I Deck the case?" And I had no local Type 4 machine shop. A type 1 guy took a look but did not measure anything. He noted this on mine: With the case split, look at the mating surfaces above and below the bearing. The round areas where the thru bolts go. The areas around the middle bearing (#2?) were very smooth, like there had been movement. the other bearing areas still had machine marks from the factory. I finally found a small shop to measure for me. Turns out the case bore was straight. Probably need to find a type 4 or VW shop to measure stuff for you.
malcolm2
post Jan 3 2012, 11:04 AM
Len gave me a shade tree trick. Take the circle bearing without the thrust, #3 i think. Put it into each of the three bearing locations in each case 1/2. If if fits nice and tight, and you see no light under or around it, you are doing pretty good. Also you can put #1 and #4 (or #3) bearing back in leaving the middle out. place the crank in each case half and use a dial gauge placed on the the crank and turn the crank and watch the gauge. Harbor Freight has a dial guage and a stand for pretty cheap. That checks for a bent crank. 3rdly, mock up your crank and bearings with alittle oil on the bearing and torque up the case, stick you hands in and try to turn the crank. you should get 360 degrees of easy spinning. these are just warm and fuzzy ways to see what is up. Try to find a type 4 shop.
BTW from your bearing pictures, I think the PO told you the truth. Those are fairly fresh bearings.
Cool914   bearing inspection   Nov 21 2011, 11:14 AM
McMark   Inattentive rebuilder. I did that on one of my fi...   Nov 21 2011, 11:16 AM
Cool914   Inattentive rebuilder. I did that on one of my f...   Nov 21 2011, 12:09 PM
Cool914   So I started to take my "rebuilt" motor ...   Nov 25 2011, 11:20 PM
Cool914   Last one of intake and some of cylinders. They loo...   Nov 25 2011, 11:28 PM
Mark Henry   Looks like bus pistons. Heads don't look too b...   Nov 26 2011, 12:05 AM
bam914   I would have the valves replaced that one with all...   Nov 26 2011, 09:30 AM
jmill   I would have the valves replaced that one with al...   Nov 26 2011, 09:42 AM
jcd914   looks like one intake valve and guide have been r...   Nov 26 2011, 11:06 AM
Jake Raby   Reusing valves is Russian Roulette.. Especially th...   Nov 26 2011, 02:56 PM
MrHyde   Looks like bus pistons. Heads don't look too ...   Nov 26 2011, 03:50 PM
Cool914   Thanks for the advice everyone. They will be getti...   Nov 26 2011, 07:03 PM
Dave_Darling   Very common; that's the cover over the bottom ...   Nov 26 2011, 11:33 PM
sean_v8_914   post #12 is a tribute to Sir Andy   Nov 27 2011, 09:33 AM
Cool914   Do I need a new clutch disc? Seriously though, do ...   Nov 28 2011, 06:02 PM
mrholland2   Do I need a new clutch disc? Seriously though, do...   Jan 2 2012, 10:33 PM
a914dude   Down to the rivits? Yes.   Nov 28 2011, 06:16 PM
Mark Henry   When you come down to see me bring it with you, I ...   Nov 28 2011, 06:47 PM
Cool914   So I finally had time to finish the tear down. Did...   Jan 2 2012, 08:49 PM
Cool914   the rest   Jan 2 2012, 08:56 PM
Cool914   sorry, here is a good one of the impression of t...   Jan 2 2012, 09:00 PM
SirAndy   This is hurting my eyes! :poke: Find the ma...   Jan 2 2012, 09:03 PM
Cool914   This is hurting my eyes! :poke: Find the m...   Jan 2 2012, 09:08 PM
malcolm2   All those bearings look brand new compared to mine...   Jan 2 2012, 09:25 PM
Cool914   All those bearings look brand new compared to min...   Jan 2 2012, 09:28 PM
messix   that whole mess is ugly, rebuilt when? and you ar...   Jan 2 2012, 10:53 PM
Cool914   I don't have any history on the engine, was to...   Jan 2 2012, 11:14 PM
malcolm2   I don't have any history on the engine, was t...   Jan 3 2012, 10:54 AM
malcolm2   Anyone have any comments on the hammering of the...   Jan 3 2012, 11:04 AM
Cool914   Anyone have any comments on the hammering of th...   Jan 3 2012, 09:38 PM
76-914   Andy is just jazzing you about the photo's. A ...   Jan 3 2012, 09:32 AM
Cool914   Andy is just jazzing you about the photo's. A...   Jan 3 2012, 09:49 AM
underthetire   This one looks toast for sure..   Jan 3 2012, 10:20 AM
Cool914   This one looks toast for sure.. That was from my...   Jan 3 2012, 10:29 AM
Valy   You need new bearings. All of them for sure. You m...   Jan 3 2012, 04:47 PM
Jeff Hail   The more I look the more I see. May not be anyt...   Jan 3 2012, 08:22 PM
Cool914   The more I look the more I see. May not be any...   Jan 3 2012, 09:40 PM
- Lo-Fi Version Time is now: 1st August 2025 - 06:49 PM
