Replacing fuel lines, Not as easy as I tought |
mikea100 |
Dec 28 2011, 03:05 PM
Member Group: Members Posts: 180 Joined: 28-December 09 From: Edison, NJ Member No.: 11,182 Region Association: North East States |
While replacing my fuel lines I noticed that they're metal from shifter lever going forward and plastic going back.
Here're my steps. First, I removed the fuel tank and noticed that fittings on the outside firewall are metal (Picture 1). Then I removed front tunnell access plate and the lines were metal (Picure 2). I thought that it was nice of PO to have them replaced. But when I removed rear tunnell access plate the lines were plastic. I wanted to trace the entire line and removed shifter lever and saw a some kind of connector that hooks up metal line to plastic (Picure 3). Is this stock setup? (IMG:style_emoticons/default/WTF.gif) I purchased a comlete set from Tangerine and those lines will replace everything firewall to firewall. However, I noticed that fittings (Picture 4) are much smaller than the ones that are there now (Compare Pic 1 to Pic 4). Should I be concerned sbout that? Happy New Year! (IMG:style_emoticons/default/beerchug.gif) Mike Attached thumbnail(s) |
pete000 |
Jan 5 2012, 10:32 AM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
I am just a couple steps ahead of you. I thought the same thing when I saw the stock metal lines under the tank. Just the way Porsche did it. The plastic was high tech back then and cheap.
I left the shifter in doing the swap, but now I see in your pictures the lines are held down with tabs, Might have to double check mine make sure I have the lines going through there. (IMG:style_emoticons/default/idea.gif) I also did the front sway bar while I had the tank out. |
RiqueMar |
Jan 5 2012, 10:48 AM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Sorry if this is hijacking, but has anyone done this with AN fittings already fitted to the hoses? I have the SS lines, and am trying to wrap my head around how to install them after I put the fittings on.
Lo-Fi Version | Time is now: 15th June 2024 - 11:15 PM |
