| mrholland2 |
Jan 5 2012, 01:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 761 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Hey all,
I asked a question on an old thread and maybe I just need to start a new one: On a carbbed car, what is/are the advantages of a vacuum advance distributor, if any over mechanical? Or is it the other way around? What reasonably priced solution should I use? (IMG:style_emoticons/default/confused24.gif) I am pretty sure mine is vacuum challenged and needs replacing (my mechanic says I should replace it and seek advice from the 914 experts, since he is a fairly talented generalist) (IMG:style_emoticons/default/idea.gif) Thanks Sean |
| 914Mels |
Jan 5 2012, 01:36 PM
Member ![]() ![]() Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
You can get more total advance out of a mechanical/vacuum combination with out burning up your motor. Under a light load the vacuum will advance your timing to take advantage of the lower stress on the engine. It should increase you mileage and power over a mechanical only distributor.
| willamp |
Jan 5 2012, 01:58 PM
Drivin' in Texas Hill Country ![]() ![]() Group: Members Posts: 76 Joined: 1-October 10 From: Austin, Texas Member No.: 12,232 Region Association: None |
You can get more total advance out of a mechanical/vacuum combination with out burning up your motor. Under a light load the vacuum will advance your timing to take advantage of the lower stress on the engine. It should increase you mileage and power over a mechanical only distributor. (IMG:style_emoticons/default/agree.gif) With the SVDA (single vacuum, dual advance (mechanical and vacuum)) that I purchased I don't notice any flat spots and acceleration just seems to come on a little quicker. What I mean by that is, say you're just tooling along at 45-50 in 4th gear with the pedal barely depressed at all, then the speed limit increases and you press the pedal in further with a plan to speed up to 60 and go to 5th gear. With the new distributor there just seems to be torque available with the slightest depression of the pedal but with the old one (bosch 009) there seemed to be a time delay and you just had push further before anything happened. I assume when pressing the pedal under this circumstance you are in the highly advanced situation so that's why it it's got more pep. This has been my impression of what people were always referring to as a 'flat spot'. Not completely sure if that's true or not. But, I can say I like this distributor. 034 svda |
mrholland2 Still not understanding distributor choices well Jan 5 2012, 01:23 PM
mrholland2 Thanks to both of you, I now know exactly what I w... Jan 5 2012, 05:28 PM
jcd914 Your carbs will need to have a "ported" ... Jan 5 2012, 08:11 PM
mrholland2 Thanks Jim, I think mine is ported already, but I... Jan 5 2012, 09:14 PM
aharder
Your carbs will need to have a "ported... Jan 5 2012, 09:37 PM
clapeza Aircooled.net offers installing a vacuum port as o... Jan 6 2012, 07:45 AM
brant I've had 4 sets of carbs on 914's over the... Jan 5 2012, 09:49 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:23 AM |
