> Still not understanding distributor choices well, Remember I'm a music teacher LOL
mrholland2
post Jan 5 2012, 01:23 PM
Hey all,
I asked a question on an old thread and maybe I just need to start a new one:
On a carbbed car, what is/are the advantages of a vacuum advance distributor, if any over mechanical? Or is it the other way around? What reasonably priced solution should I use? (IMG:style_emoticons/default/confused24.gif)
I am pretty sure mine is vacuum challenged and needs replacing (my mechanic says I should replace it and seek advice from the 914 experts, since he is a fairly talented generalist) (IMG:style_emoticons/default/idea.gif)
Thanks
Sean
jcd914
post Jan 5 2012, 08:11 PM
Your carbs will need to have a "ported" vacuum fitting for the advance. Most aftermarket carbs do not have this out of the box.
It is a percision drilled hole with a vacuum hose nipple. The hole is blocked by the closed throttle plate and progressively gets vacuum as the throttle is opened.
Jim
mrholland2
post Jan 5 2012, 09:14 PM
Thanks Jim, I think mine is ported already, but I shall double check.
Sean
QUOTE(jcd914 @ Jan 5 2012, 06:11 PM) *
Jim
- Lo-Fi Version Time is now: 2nd April 2026 - 08:50 AM
