Gas Tank, Fuel Lines |
doit2xs |
Jan 5 2012, 06:48 PM
Newbie Group: Members Posts: 20 Joined: 15-February 06 From: Mascotte, Florida Member No.: 5,588 Region Association: None |
Hi, anybody know on the gas tank when using carbs, do you block off the 5/16" line that has the baffle and use the 3/8" line that goes straight through? Do I get a cap to block it off, or just use a piece of fuel line and a bolt?
Thanks, Don |
mrbubblehead |
Jan 5 2012, 07:09 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i used these http://www.vwparts.net/CB3288.html then cap off the non screened port (return port)
doit2xs |
Jan 5 2012, 08:00 PM
Hi, screened port? I did not see a screen? Did you get cap at parts store? |
mrbubblehead |
Jan 5 2012, 08:54 PM
Hi, screened port? I did not see a screen? Did you get cap at parts store? if you look inside your fuel tank with a flashlight you will see a screen/filter in there. thats the one you will use for your carbs. the other one can be capped off. i get my fittings from summit. except for the fuel tank fittings because summit doesnt carry them. this is a -6 cap for the tank fitting. http://www.summitracing.com/parts/AER-FBM3740/ for 15 dollars worth of fittings, i think its alot safer than a bolt and hose clamp. |
doit2xs |
Jan 5 2012, 10:48 PM
Hi, screened port? I did not see a screen? Did you get cap at parts store? if you look inside your fuel tank with a flashlight you will see a screen/filter in there. thats the one you will use for your carbs. the other one can be capped off. i get my fittings from summit. except for the fuel tank fittings because summit doesnt carry them. this is a -6 cap for the tank fitting. http://www.summitracing.com/parts/AER-FBM3740/ for 15 dollars worth of fittings, i think its alot safer than a bolt and hose clamp. I used a flashlight and one port has a metal plate with a hole in it, the 5/16" one. And the other is wide open the 3/8" one, and you can see out the filler. But no screen. Do you know where I can get the screen? Thanks |
rick 918-S |
Jan 6 2012, 08:42 AM
Hey nice rack! -Celette Group: Members Posts: 20,493 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Hi, screened port? I did not see a screen? Did you get cap at parts store? if you look inside your fuel tank with a flashlight you will see a screen/filter in there. thats the one you will use for your carbs. the other one can be capped off. i get my fittings from summit. except for the fuel tank fittings because summit doesnt carry them. this is a -6 cap for the tank fitting. http://www.summitracing.com/parts/AER-FBM3740/ for 15 dollars worth of fittings, i think its alot safer than a bolt and hose clamp. I used a flashlight and one port has a metal plate with a hole in it, the 5/16" one. And the other is wide open the 3/8" one, and you can see out the filler. But no screen. Do you know where I can get the screen? Thanks Several places sell the screen. Check out the member vendor section here on 914World. http://www.914world.com/bbs2/index.php?showforum=4 If you haven't replaced the plastic line in the tunnel you may want to check out Chris Foley's site. You should consider replacing these lines. They are starting to age out and we have had several of our members loose their cars to fires. http://www.tangerineracing.com/stainlessFuelLines.htm He has a nice stainless steel line kit and also sells the filter screen. And if I didn't say it before.... (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 10th June 2024 - 12:55 AM |
