| 75boxster |
May 7 2004, 06:49 PM
Member ![]() ![]() Group: Members Posts: 89 Joined: 1-January 04 From: Ft. Collins, CO Member No.: 1,488 |
Webers are brand new and seem to fall out of tune(especially part throttle) very quickly. I know nothing about carbs so this is very frustrating. I feel much more comfortable with electronic control and tuning. I am looking to talk to the guys who have an aftermarket system on a flat four and have had good luck with it. Can this be done for $2500? Also in the mean time where do I look to learn a bit about these damn Webers and some rookie tuning instructions.
Signed, Carb ignorant. |
| Dave_Darling |
May 7 2004, 07:09 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
There are two Weber books, the Weber Tech Manual and the Haynes manual for Webers. I think the Tech Manual is written by Pat Braden. They are well thought of by those I have talked to who have fussed with the Webers.
Megasquirt is an option, but if your Big Four is much bigger than 2 liters you will probably have to fabricate an intake manifold yourself or find something adapable. Heh, or you can just use your Webers as throttle bodies and set up the MS (or other FI system) as an "Alpha-N" system, which reads throttle position (alpha) and RPM (N) and uses those inputs instead of air flow or manifold pressure... Sort of like an electronic MFI. --DD |
75boxster I hate carbs! May 7 2004, 06:49 PM
anthony You could probably do Megasquirt for less than ... May 7 2004, 06:56 PM
nebreitling what's your engine's specs? cam?
there... May 7 2004, 06:59 PM
Jake Raby I last adjusted my carbs on the 912E in February o... May 7 2004, 07:16 PM
75boxster Motor is a 2413, I know how we all feel about that... May 7 2004, 07:47 PM
Jake Raby That explains alot... One problem with the huge bo... May 7 2004, 08:41 PM
Peter_Hinkle I live in Denver and run webers with absolutely no... May 7 2004, 11:06 PM
Jake Raby Its all in the set up.... linkage is of utmost imp... May 7 2004, 11:11 PM
Aaron Cox :agree:
get the super CB performance linkage, yo... May 8 2004, 11:58 AM
KitCarlson Hi!
A KitCarlson EMS Update!
This week I... May 8 2004, 12:49 PM
Jake Raby Seriously looking forward to it......
I can give ... May 8 2004, 07:06 PM
cnavarro Kit, when are you going to be at Brad's? I... May 8 2004, 07:11 PM
75boxster Ok, I am ready to buy! When can the common sh... May 9 2004, 12:00 AM
Lawrence Kit,
When you visit Brad, please let him know I s... May 9 2004, 02:18 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:09 AM |
