> Its Suspension Time!, anyone with tips tricks?
cha914
post Jan 14 2003, 11:52 AM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus
Starting friday I will be pulling the suspension off the 914 and
- installing Koni sports all around with the fully adj perches in the rear
-new poly bushings all around (from weltmeister...street compound)
-turbo tie rod kit
-new ball joints
...anyway...this is the last part of the 914 that I haven't pulled off the car yet, so its time. any, tips, hints that you have will be much appreciated. I am going to be doing this with the help of a lift and plenty of tools...so I am hoping to knock this out over the weekend...doable?
Thanks,
Tony
Jeroen
post Jan 14 2003, 03:53 PM
Region Association: Europe
I got that one... won't work on the strut/balljoint
Couldn't get the tie-rods off with it either.
I used a different tool for the tie-rods.
I was scared the tool would break (not good if it's a loaner), but the tie-rod gave first
Darn, this stuff can get stuck!
Cheers,
Jeroen
cha914   Its Suspension Time!   Jan 14 2003, 11:52 AM
Bleyseng   Brad is having a class this saturday on front susp...   Jan 14 2003, 02:24 PM
J P Stein   Are those gas shox? If not, the fronts are a stink...   Jan 14 2003, 02:32 PM
cha914   Unfortunately the drive to CA and back from TX wou...   Jan 14 2003, 03:06 PM
Jeroen   How the fuck do you get the friggin struts off the...   Jan 14 2003, 03:37 PM
bhfast   ball joint seperator it looks like a big fork, but...   Jan 14 2003, 03:48 PM
bhfast   local auto parts store should have it for around ...   Jan 14 2003, 03:49 PM
J P Stein   I didn't mean to sound rude. I take a much mor...   Jan 14 2003, 03:52 PM
Jeroen   I got that one... won't work on the strut/ball...   Jan 14 2003, 03:53 PM
bhfast   when i did mine it didjn't work either, so i u...   Jan 14 2003, 03:58 PM
Brad Roberts   Here is how to get the ball joint out of the strut...   Jan 14 2003, 04:31 PM
cha914   I didn't take anything as rude...just want to ...   Jan 14 2003, 04:33 PM
Bleyseng   Yeah, the ball joints get rusted in place to the s...   Jan 14 2003, 04:37 PM
Brad Roberts   Tony. With proper tools.. I takes me 8 hours to c...   Jan 14 2003, 04:38 PM
Brad Roberts   I dont use heat.. ever. Your lower ball joints don...   Jan 14 2003, 04:40 PM
cha914   ok...thats good info...I will plan on at least dou...   Jan 14 2003, 04:56 PM
Bleyseng   Well if you use too friggin much heat! Just a ...   Jan 14 2003, 05:14 PM
Brad Roberts   I tried to take pics of it... but none of them tur...   Jan 14 2003, 05:24 PM
cha914   Ok...I have a little dremel... how deep of a cut....   Jan 14 2003, 05:30 PM
Brad Roberts   Umm.. half the thickness of a No.2 Pencil (the yel...   Jan 14 2003, 05:33 PM
cha914   sorry, I got confused...when you said thickness, I...   Jan 14 2003, 05:55 PM
Mueller   Back in the old days when I ran poly bushings inst...   Jan 14 2003, 06:12 PM
Bleyseng   Nice pic! Thanks, you sell those too?? Geoff :...   Jan 14 2003, 07:41 PM
Brad Roberts   Mike would whore his ass out if he had too. :sho...   Jan 14 2003, 07:44 PM
cha914   hang in there mike...maybe in a year I will be giv...   Jan 14 2003, 09:13 PM
Gint   This is what it looks like when you get it all out...   Jan 14 2003, 11:08 PM
cha914   That looks real nice ginter...but mine are going t...   Jan 15 2003, 12:21 AM
Jeroen   wow! nice clean up! did you have all that ...   Jan 15 2003, 02:57 AM
Gint   I bead blasted it and powder coated it all right i...   Jan 15 2003, 10:32 AM
gklinger
- Lo-Fi Version Time is now: 25th November 2026 - 10:52 PM
