Installing new Rubber Engine Compartment Seals, What to lubricate them with |
euro911 |
Jan 12 2012, 11:30 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Since the drive train is out and Milt fixed the engine shelf in my '75, I'm getting ready to install new [914rubber.com] seals around the engine compartment.
The old ones were hard and brittle (what was left of them), and I had to bend the rails on the slots apart a little to get them out. What do you guys use to lubricate new seals so they don't bind or tear when pulling them in? (IMG:style_emoticons/default/popcorn[1].gif) |
John |
Jan 12 2012, 11:12 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
When I lubricate rubber parts for assembly, I use P-80 rubber lubricant. It is formulated as an assembly lube and does not damage rubber.
By the way, WD40 contains no silicone. I also push the engine shelf seals in with a small flat blade screwdriver. |
Lo-Fi Version | Time is now: 8th June 2024 - 10:18 PM |
