> Tapered Fuel Hose, No longer availabe at Pelican Parts
JawjaPorsche
post Jan 16 2012, 04:55 PM
I see where the Tapered Fuel Hose is no longer available at Pelican Parts:
http://www.pelicanparts.com/cgi-bin/smart/...74%29%2C%20Each
Does anyone know an alternative source?
Also dumb question. The description says "Tapered Fuel Hose For Connection at Fuel Filter."
I thought the hose was also used for the outlet port on the fuel pump because the connection is smaller than the standard hose size: 8 mm?
JawjaPorsche   Tapered Fuel Hose   Jan 16 2012, 04:55 PM
billh1963   I thought it was only for the fuel tank line comin...   Jan 16 2012, 05:12 PM
wingnut86   Check Automation and Vertex. They used to carry t...   Jan 16 2012, 05:50 PM
type47   Chris Foley sells a stainless steel piece that doe...   Jan 16 2012, 06:12 PM
Racer Chris   Chris Foley sells a stainless steel piece that do...   Jan 16 2012, 06:42 PM
SLITS   Gad, go to ACE Hardware or a place like that and g...   Jan 16 2012, 06:47 PM
Cap'n Krusty   Gad, go to ACE Hardware or a place like that and ...   Jan 16 2012, 08:19 PM
SLITS   Gad, go to ACE Hardware or a place like that and...   Jan 17 2012, 10:23 AM
dangrouche   I employ Chris' taper stainless adaptor tubing...   Jan 16 2012, 07:46 PM
rick 918-S   I employ Chris' taper stainless adaptor tubin...   Jan 17 2012, 12:03 AM
ClayPerrine   If IIRC, there is a Mercedes Diesel hose that wor...   Jan 17 2012, 10:30 AM
Phoenix914   If IIRC, there is a Mercedes Diesel hose that wo...   Aug 5 2014, 11:12 AM
Dave_Darling   Your hardware store will have hose barbs and fitti...   Aug 5 2014, 01:27 PM
Phoenix914   Thanks Dave. I'll probably go that route. Th...   Aug 5 2014, 01:34 PM
pete000   Glad I got one a few years back when I started my ...   Aug 5 2014, 02:16 PM
Phoenix914   good grief I need to get my car going again ...   Aug 5 2014, 02:39 PM
bdstone914   good grief I need to get my car going again ...   Aug 5 2014, 06:58 PM
Phoenix914   I made one out of a piece of hose that was the co...   Aug 5 2014, 07:24 PM
Racer Chris   Trying to find that tapered hose is a waste of tim...   Aug 5 2014, 03:14 PM
mepstein   I bought mine from Chris - Tangerine. He has all t...   Aug 5 2014, 08:06 PM
pete000   I noticed Sierra Madre lists them as NLA now too.....   Aug 6 2014, 11:18 PM
Phoenix914   That looks like a nice piece, and cheaper than a M...   Aug 7 2014, 05:09 AM
Racer Chris   That Jegs piece is perfect.   Aug 7 2014, 06:16 AM
Phoenix914   That Jegs piece is perfect. Looks like it might...   Aug 7 2014, 06:22 AM
Racer Chris   That Jegs piece is perfect. Looks like it migh...   Aug 7 2014, 07:45 AM
stinkindiesel   Has anybody identified a suitable fuel filter with...   Aug 19 2014, 03:45 PM
Kansas 914   Has anybody identified a suitable fuel filter wit...   Aug 19 2014, 07:51 PM
stinkindiesel   I used to buy mine from Brad at 914ltd.com. He do...   Aug 20 2014, 07:47 AM
Racer Chris   Yep, the WIX 33274 is the correct one that has th...   Aug 20 2014, 08:30 AM
stinkindiesel   Yep, the WIX 33274 is the correct one that has t...   Aug 20 2014, 12:22 PM
Dave_Darling   Has anybody identified a suitable fuel filter wit...   Aug 19 2014, 09:09 PM
pete000   Fram makes an all metal filter with the 3/8 (10mm)...   Aug 19 2014, 09:07 PM
mapguy   Awesome! That Wix unit is just the ticket...   Aug 19 2014, 11:01 PM
bandjoey   Bought one like the wix. Don't remember the br...   Aug 20 2014, 07:55 AM
Phoenix914   Has anybody used this WIX filter? The description...   Nov 18 2014, 10:06 AM
Racer Chris   Has anybody used this WIX filter? The descriptio...   Nov 18 2014, 11:25 AM
Phoenix914   Wix 33002 is a better choice. 8mm inlet and outl...   Nov 18 2014, 01:15 PM
dcheek   VW uses a similar hose. I ordered one for one of m...   Nov 18 2014, 02:34 PM
Mikey914   I personally don't like Wix. I had a problem w...   Nov 18 2014, 11:59 PM
dcheek   This is the one I used on my Rabbit a while back. ...   Nov 19 2014, 03:27 PM
Phoenix914   This listing says the hose is 7/11 mm. :idea: ...   Nov 19 2014, 04:10 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 08:36 AM
