lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
In another thread, TimT posted a graph produced by Pratt & Whitney showing the relationship of CGT, EGT, mixture, and power in air-cooled aero engines. Despite the often held assertion here and elsewhere that "our" engines need to run rich to stay cool, the chart showed that CHT fell as the mixture got leaner from "best power" (about 13:1). It also fell as it got richer from best power. There was a question in my mind how well this generalized to the Type IV.
My 1.7 w/ Webers had been, I knew, running rich on the idle circuits, and I was waiting on a set of leaner idle jets. These showed up, and I installed them this morning (50s down from 55s). Crisper running, and I hope much better gas mileage (was below 20mpg). My CHT gauge held the real surprise, however. It's installed on the hottest cylinder (No. 3), and previously warmed up very quickly to 300dF after just 30 seconds or so after a cold start. It would climb to 350dF as soon as any load was put on the engine, and up to 400dF when pulling up a two-mile long 6% grade near my house. With the leaner idle jets and no other changes, it was much slower to warm up, and never exceeded 275dF idling and puttering around the neighborhood at 25mph. Up that long hill, it just barely touched 350dF. I don't have a wideband mixture meter (yet), so I have no idea if I'm still rich or somewhat lean. Drivability is still good, so it can't be all that lean. I haven't yet tried to do a plug check (used to be sooty black). In any case, it's one data point that seems to support the P&W chart. |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Put an aircooled engine at 17.7:1 and watch it fry.. Most of my best power and cooling stettings are at 13:1
Aircraft have a totally different group of settings. For one that are at higher elevation and have different ambient air temperatures and pressures AND the engine is working just inside a cowling with fresh air blowing through keeping charge temperatures down. They also work with less load that a vehicle typically sees. Yes a huge prop creates load but at the same time you are only keeping it loaded during changes in airspeed, climbing and doing maneuvers... at cruise and constant airspeed the load is lower . This is exactly why they recommend in the article to enrich during these times and lean out during cruise.. Most of my aircraft experiences have been with Turboshafts, but I have been trained with piston engines as well. Keep in mind that "avgas" is 100 octane low lead and is filled with its own coolants to enhance the burn with the cylinder pressures that typical aircraft engines have- this changes everything and is one reason it cannot accurately be compared to a ground vehicle on 91 octane pump gas which is in many cases "oxygenated" Keep the engine at the point where it wants to run coolest and make the most power and you'll be just fine- sorry but you'll have to have a dyno to find that without dialing in for a week... I dial my engines in with use of a wide band O2 meter and a fuel flowrator to measure BSFC and plot it. |
Lo-Fi Version | Time is now: 15th July 2025 - 02:39 AM |
