> Joes 2056 build thread, Its Driving again !!!!!!!!!!!!!!!!
jsayre914
post Sep 12 2011, 04:32 PM
Speed Up !!!
I have been searching all the 2056 threads. Their should really be a 2056 for dummies thread (IMG:style_emoticons/default/biggrin.gif)
I plan on building a 2056 D-jet from my stock 2.0 1973 motor. I have been collecting parts since 2009 (IMG:style_emoticons/default/rolleyes.gif)
Here is what I got so far:
2.0 motor (havent split it yet)
D-Jet system off my 73
4 cleaned & Tested injectors
new wiring harness from bowlsby
new tps board
new hoses
rabby 9550 cam kit
1.8 rockers and swivel feet
aa 96mm cylinder & pistons
I might be forgettin a few things, it has been a while. (IMG:style_emoticons/default/idea.gif)
The heads should be sent out within the week to be checked and prepared with new seats, valves, etc. And I will be splitting the case open this week also. All the cool kids are doing it (IMG:style_emoticons/default/smile.gif)
What other thing do I need to purchase as I begin???
gaskets, bearings, flywheel ??? (IMG:style_emoticons/default/confused24.gif)
also what tools are required other than the basic tools?
I never done this before
(IMG:style_emoticons/default/hide.gif)
thanks
Joseph
Dr Evil
post Jan 19 2012, 07:06 PM
Send me your transmission!
Bead blast! Ah yes, make sure you clean the case out thoroughly! All the passages and such. You dont want that grit getting into your running parts.
tscrihfield
post Jan 19 2012, 07:11 PM
Drive Fast and Take Chances
QUOTE(Dr Evil @ Jan 19 2012, 08:06 PM) *
I would spend a ton of time cleaning that thing to avoid any loose grit getting into the engine when complete!
I used to use pipe cleaners that are really long or take out all of the oil galley plugs and run a 22 cal barrel brush through it!
jsayre914   Joes 2056 build thread   Sep 12 2011, 04:32 PM
Valy   1.8 rockers and swivel feet I think you want the...   Sep 12 2011, 05:46 PM
jsayre914   I think you want the 1.7 rockers to go with the R...   Sep 14 2011, 02:03 PM
jsayre914   And those injectors... if they've been waiti...   Jan 12 2012, 04:25 PM
yeahmag   I think these days you will need to buy a "ca...   Sep 12 2011, 06:10 PM
Vacca Rabite   I think Joe got the cam kit, not just the cam. Yo...   Sep 12 2011, 07:36 PM
jsayre914   adding to the list... victor reinz gasket set for...   Sep 21 2011, 01:36 PM
HAM Inc   Joe when you get your rotating assembly balanced b...   Sep 21 2011, 02:22 PM
jsayre914   Joe when you get your rotating assembly balanced ...   Sep 21 2011, 03:00 PM
Vacca Rabite   you dont need an engine stand. my yolk is welded ...   Sep 21 2011, 02:24 PM
vsg914   You'll need a dial indicator for setting the v...   Sep 21 2011, 02:48 PM
jsayre914   You'll need a dial indicator for setting the ...   Sep 21 2011, 03:04 PM
DNHunt   I don't know if anyone mentioned a rear main s...   Sep 21 2011, 04:48 PM
jsayre914   I don't know if anyone mentioned a rear main ...   Sep 23 2011, 01:55 PM
vsg914   I bought mine at hf, but I got the better one.   Sep 21 2011, 05:01 PM
Vacca Rabite   I have an adjustable push rod and dial indicator. ...   Sep 21 2011, 07:47 PM
jsayre914   I have an adjustable push rod and dial indicator....   Sep 22 2011, 07:33 AM
Vacca Rabite   See you then my double posting friend. :) Zach   Sep 22 2011, 08:52 AM
jsayre914   These just came today :D Sure r purdy :wub:   Oct 6 2011, 11:08 AM
type47   These just came today :D hmmm :drooley: , fr...   Oct 6 2011, 01:24 PM
jsayre914   [quote name='jsayre914' post='1550174' date='Oct ...   Oct 6 2011, 02:38 PM
Vacca Rabite   I'm glad you decided tO get them.   Oct 6 2011, 05:25 PM
jsayre914   Sooo, when I send my case off to Rimco. I tell th...   Oct 7 2011, 05:23 PM
Vacca Rabite   NO! Send your case to Mark at Warrior Motors i...   Oct 7 2011, 05:27 PM
jsayre914   NO! Send your case to Mark at Warrior Motors ...   Oct 7 2011, 05:29 PM
Valy   NO! Send your case to Mark at Warrior Motors...   Oct 7 2011, 07:09 PM
jsayre914   Minor Setback. I was pulling out my stash of parts...   Nov 9 2011, 03:04 PM
scotty b   It's toast, and the AA's are a crap shoot ...   Nov 9 2011, 03:40 PM
914rat   You can buy just 1 jug from AA.The stock jugs are ...   Nov 9 2011, 05:05 PM
Vacca Rabite   Yep, bore the stock ones. They are better then the...   Nov 9 2011, 06:03 PM
jsayre914   Few more pics of the guts before bed :) ...   Nov 9 2011, 11:13 PM
jsayre914   Dropped the case off with Mark @ Warrior yesterday...   Nov 16 2011, 03:55 PM
draganc   Dropped the case off with Mark @ Warrior yesterda...   Nov 16 2011, 08:01 PM
Vacca Rabite   I'm a big fan of Marks work. Not only does he ...   Nov 16 2011, 04:04 PM
Vacca Rabite   Warrior Motors in Dallastown PA (near York). Prob...   Nov 16 2011, 08:08 PM
draganc   Warrior Motors in Dallastown PA (near York). Pro...   Nov 16 2011, 08:11 PM
jsayre914   Called Warrior motors once a week for the last 3 w...   Dec 14 2011, 01:20 PM
Vacca Rabite   Dude, I am very sorry. Mark was always really fast...   Dec 14 2011, 04:43 PM
jsayre914   Cant be long now.... any day.... :popcorn: :p...   Dec 27 2011, 08:54 PM
Vacca Rabite   Next tuesday stop by marks shop to see if he is in...   Dec 28 2011, 08:08 AM
saigon71   Joe: I hope everything works out with Marks shop....   Dec 29 2011, 07:44 AM
76-914   I also have Jakes engine video. Swing over a...   Dec 29 2011, 09:57 AM
mepstein   I also have Jakes engine video. Swing over ...   Dec 29 2011, 10:13 AM
Vacca Rabite   [quote name='Vacca Rabite' post='1538399' date='S...   Dec 29 2011, 10:46 AM
76-914   [quote name='Vacca Rabite' post='1538399' date='...   Dec 30 2011, 09:34 AM
mepstein   [quote name='Vacca Rabite' post='1596638' date='D...   Dec 30 2011, 09:42 AM
jsayre914   Since we are heading off topic anyway, and I am wa...   Dec 29 2011, 01:11 PM
jsayre914   So I got a call from the powder shop. Everything i...   Dec 30 2011, 12:03 PM
jsayre914   Going to Warrior tommorow. (wish me luck) will po...   Jan 2 2012, 04:30 PM
jsayre914   As promissed :drooley: I think they did an outs...   Jan 3 2012, 10:20 AM
jsayre914   And the original Heads brought to life by Len :el...   Jan 3 2012, 10:23 AM
jsayre914   Next stop.... WARRIOR ENGINE to see if my 94mm a...   Jan 3 2012, 10:25 AM
hot_shoe914   Would you quit Fuching around and finish this thin...   Jan 3 2012, 09:00 PM
jsayre914   Would you quit Fuching around and finish this thi...   Jan 4 2012, 12:26 PM
SirAndy   The finish line is in sight. Is it done yet? :co...   Jan 4 2012, 12:31 PM
jsayre914   Is it done yet? :confused: :chair: Do you w...   Jan 4 2012, 12:49 PM
type47   And there's a problem with that? 7 degrees out...   Jan 4 2012, 01:07 PM
Jake Raby   Dean told you the truth about the bushings... The ...   Jan 4 2012, 01:55 PM
Vacca Rabite   Those heads make me jealous. Zach   Jan 4 2012, 08:42 PM
mepstein   Those heads make me jealous. Zach Joe - Give Z...   Jan 11 2012, 11:39 AM
jsayre914   Those heads make me jealous. Zach Joe - Give ...   Jan 12 2012, 04:26 PM
jsayre914   Talked with Mark just now. He said I can pick ever...   Jan 11 2012, 11:23 AM
saigon71   Talked with Mark just now. He said I can pick eve...   Jan 12 2012, 09:15 PM
jsayre914   Everything is ready to go back togeather :Qarl: ...   Jan 17 2012, 12:43 PM
Dr Evil   Please dont mess this up :poke:   Jan 17 2012, 04:33 PM
hot_shoe914   Please dont mess this up :poke: Help him doc. :p...   Jan 17 2012, 11:39 PM
Dr Evil   Please dont mess this up :poke: Help him doc. :...   Jan 18 2012, 08:09 AM
Vacca Rabite   Just ask questions and if I can I will swing over ...   Jan 18 2012, 07:14 AM
saigon71   Looks good Joe...glad you finally got all the part...   Jan 18 2012, 08:43 AM
Racer Chris   Joe, I'm expecting to ship your new exhaust an...   Jan 18 2012, 10:11 AM
jsayre914   Joe, I'm expecting to ship your new exhaust a...   Jan 18 2012, 10:38 AM
Vacca Rabite   THAT! YOU BUM! Its never going to reac...   Jan 18 2012, 07:35 PM
scotty b   That may be the cleanest engine I hve ever seen :b...   Jan 19 2012, 10:41 AM
bozo914   Mmmm - Nice jugs........Looking very sanitary :agr...   Jan 19 2012, 10:49 AM
jsayre914   I now have a case of Loose cannon waiting for the ...   Jan 19 2012, 10:46 AM
yeahmag   Oh man! I love that beer! I now have a ...   Jan 19 2012, 10:59 AM
Porschef   I now have a case of Loose cannon waiting for the...   Jan 20 2012, 08:49 AM
jsayre914   I now have a case of Loose cannon waiting for th...   Jan 20 2012, 02:30 PM
jsayre914   Thanks to whomever told me to recheck my injectors...   Jan 19 2012, 11:01 AM
Gint   That bead blasted case is beautiful!   Jan 19 2012, 06:54 PM
Dr Evil   Bead blast! Ah yes, make sure you clean the ca...   Jan 19 2012, 07:06 PM
tscrihfield   Bead blast! Ah yes, make sure you clean the c...   Jan 19 2012, 07:11 PM
Vacca Rabite   Mark painted that case, didn't he. Is it real...   Jan 19 2012, 07:47 PM
Dr Evil   Maybe time to put in threaded galley plugs so you ...   Jan 19 2012, 08:36 PM
jsayre914   anybody wanna put my engine togeather sat evening?...   Jan 20 2012, 10:30 PM
Vacca Rabite   I was over Sat night... Joe is going to have a ver...   Jan 22 2012, 10:11 AM
tscrihfield   I was over Sat night... Joe is going to have a ve...   Jan 22 2012, 11:05 AM
Dr Evil   Permatex is fine. Anaerobic sealant is what you ar...   Jan 22 2012, 11:40 AM
jsayre914   OMFG :drooley: These pipes are excellent Chris....   Jan 23 2012, 03:00 PM
Vacca Rabite   Yep, that's art. :jealous: And we did make it...   Jan 23 2012, 06:12 PM
hot_shoe914   Joe, I'm beginning to think you robbed a bank,...   Jan 23 2012, 06:46 PM
jsayre914   Waiting to move foreward on my engine.... I figure...   Mar 6 2012, 06:15 PM
scotty b   :poke:   Mar 6 2012, 07:52 PM
Dr Evil   Joe doesnt care about looks, its obvious :)   Mar 6 2012, 08:16 PM
scotty b   Joe doesnt care about looks, its obvious :) Ver...   Mar 6 2012, 08:28 PM
jsayre914   is it the white thats buggin you guys ?? Its not ...   Mar 6 2012, 08:22 PM
scotty b   is it the [size=3]white thats buggin you guys ?? ...   Mar 6 2012, 08:29 PM
jsayre914   Delila says it makes my car a "REAL" rac...   Mar 6 2012, 08:35 PM
jsayre914   I should have the engine back this weekend from To...   Mar 29 2012, 11:18 AM
- Lo-Fi Version Time is now: 5th March 2026 - 09:36 AM
