| 914werke |
Oct 2 2008, 03:48 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,679 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
For sale misc. items. (Pics start in 2nd post & may or may not be actual)
If you don’t see some thing you’re after, ask there's a good chance I have it. If you want something and feel the need to dicker, make offer. Trades welcome. I’m liquidating most all the stuff horded for my restoration, but left over, so I have a lot of bits and pieces. All parts are for /4 unless otherwise noted. All prices quoted less actual shipping/handling. (International sales via Fedex 100% shipping & item prepay only!) Because the majority of these items are for small $’s, Check, MO or buyer covers the fees Shipping can be combined on multiple items but in doing so *please* be patient, it can take some time to adequately pack the selection to avoid damage. Check back often, as things get snapped up Ill add more! |
| daniel951 |
Jan 21 2012, 02:31 PM
Newbie ![]() Group: Members Posts: 13 Joined: 21-January 12 From: evansville indiana Member No.: 14,036 Region Association: None |
For sale misc. items. (Pics start in 2nd post & may or may not be actual) If you don’t see some thing you’re after, ask there's a good chance I have it. If you want something and feel the need to dicker, make offer. Trades welcome. I’m liquidating all the stuff horded for my restoration, but left over, so I have a lot of bits and pieces. All parts are for /4 unless otherwise noted. All prices quoted less actual shipping/handling. (International sales via Fedex 100% shipping & item prepay only!) Because the majority of these items are for small $’s, Check, MO or buyer covers the PayPal fees (better yet check into POPMoney (IMG:style_emoticons/default/smile.gif) ). Shipping can be combined on multiple items but in doing so *please* be patient, it can take some time to adequately pack the selection to avoid damage. Check back often, as things get snapped up Ill add more! #3 Wiper motor & linkage assembly $65.00 #4 #6 Center plastic deposit tray $9.14 #7 Fresh air blower motor $50.00 #8 Fresh air blower box $30.00 #9 Fresh air controls (late) $45.00 #12 Gauge Bezel (metal) $15.00 #13 Headlight surround (white early) single $9.14 #14 Headlight surround (black late) each $9.14 #15 Late window regulators R or L $30.00 #16 OE late tie rods (screw vs pinch) pair 15.00 #17 R. Trunk spring bars (pair) $9.14 #18 Steering Rack (w/o shaft) $35.00 #19 Gravel shields (each) $25.00 #20 Headlight covers (pair) $9.14 #21 Headlight Eyebrows (pair) $9.14 #22 #23 #24 Targa Top storage Brackets (forward) per $9.14 #25 OE shifter (early or late) $30.00 #26 Gauge Cluster complete (early 120MPH, late 150MPH) $80.00 #28 Fuel/Combo guages (early & late) $20.00 #29 Front hood (PU only) $75.00 #30 Shift boot (rubber) $9.14 #31 F. turn signal lenses (pair, used cond.) $9.14 #32 F. turn signal buckets (per) $15.00 #33 A. pillar trim (per side) $15.00 #34 B. Pillar trim (per side) $9.14 #35 Front brakes (each) $15.00 #36 Rear Brakes (Pair) $45.00 #37 Headlight relay cover (black) pair $9.14 #38 Eng. Lid Grill (per) $20.00 #39 Exhaust tip w/bung $25.00 #40 Speaker pods each $20.00 #41 Retractable (late) seat belt set $45.00 #42 Seat belt latch whip (late) per $9.14 #43 Seat belt latch whip (early) per $9.14 #44 Front hood latch set $20.00 #45 Rear Deck latch set $20.00 #46 Horn set (late, pair) $25.00 #47 Black 1.7 script $9.14 #48 Round relays (black) each $4.00 #50 Chrome headlight trim rings (pair) $9.14 #51 OE Blk headlight trim rings (pair) $15.00 #55 Steering column 75-76 /4 $50.00 #58 Side marker assemblies w/Lens (per side) $30.00 #59 Headlight Bucket assemblies (restored complete pair) $125.00 #60 Rear US lens (average shape. per.) $50.00 #61 Late /4 Boge strut housings (each) $9.14 #62 Trans Ground strap $9.14 #63 Bumper Dog bones (pair) $9.14 #66 Glove box door /4 (early or late vinyl) $20.00 #67 Cam Gear $15.00 #68 Screw in Studs w/nuts (per)$1.00 #69 Transmission or early eng. mounts (NO cracks) Per. $15.00 #70 OE Valve covers Per. $10.00 #71 Alloy wheel lug bolts (Per.) $5.00 #72 Trunk Steel knockouts per $9.14 #73 Headlight bucket support steel per $9.14 #75 Black Plastic Door thresholds (late, pair) $20.00 #78 Leather Wheel Wrap $9.14 #79 Transmission Mount assemblies (complete pair) $40.00 #80 Complete wire loom (uncut) 72MY $75.00 #82 Brake fluid reservoir assembly (w/lines) $35.00 #83 Cabin Fresh air vents (per) $9.14 #84 Fuel Tank assembly (early or late) $100.00 #87 Rain tray (late) $30.00 #88 Carb Fuel Pump (Faucet style)$20.00[/s] #89 Holly fuel regulator (carb) $20.00 #91 OE Shift knob $35.00 #92 Steering rack bellows $9.14 #95 Lower dash pad(s) w/vents $25.00 #96 Lower dash pad (early no vents) $30.00 #97 Engine mount bar (Late sideshift) $30.00 #100 Heater fan outlet (single) $9.14 #106 Rain Tray Drain Tubes (pair) $25.00 #107 Impeller Fan (Early or late, all fins intact) $40.00 #108 Heat Flapper valves (L or R) $35.00 #112 Muffler hanger for late 1.8 or 2.0L $9.14 #114 Rear Trailing arm hubs (pair /4) $20.00 #119 F. hood springs (pair) $9.14 #120 Map Pocket (Black) $25.00 #121 1.7L pre-heater tin assembly (rare!) $35.00 #122 Heat vents (Cabin under dash pair) $9.14 #123 Door latch assemblies (Int. pair) $35.00 #124 Door latch assemblies (Ext. per) $9.14 #125 Longitudinal tar long plugs (set of 4) $9.14 #127 OE Trunk spring rollers (plastic) $9.14 #128 R. Tail panel section $60.00 #129 Windshield washer res. bottle (w/lines) $20.00 #130 .5 shafts (pair) $50.00 #131 Tank latch set $15.00 #132 Cabin access cover set $20.00 #133 Motor mount brackets (pair late) $25.00 #134 Fresh air valves (R or L per) $9.14 #135 Defrost Vent (R or L per) $9.14 #138 Targa top complete w/hardware $75.00 #139 Body plug set (front) $30.00 #140 E-Brake handle assembly (late) $45.00 #142 Shift knob, leather & crest $30.00 #143 Exterior Door handles (no lock cyl.) $50.00 #145 Eng. Bay Relay board (average cond.) $25.00 #146 Various Engine tin. per piece. (no 2.0L top) $9.14 #147 Side shift conversion parts (All, no trans-axle) $150.00 #150 Engine Case $75.00 #152 Headlight Eyebrows grommets (set of 6) $9.14 #157 Carpet Pieces (per)$9.14 [s]#158 Dash switch set $55.00 #160 Muffler Heat Shield $30.00 #162 Fresh air box plastic grate $25 #164 Rebuilt Pedal cluster $125.00 #166 Front suspension PU $35.00 #169 Defrost R. Window Glass $50.00 #171 Formed Glove box (w/strap) $20.00 #172 Engine Windage tray/oil PU $30.00 #174 1.7L D-Jet FI harness $40.00 #175 Eng. Shroud flap assembly $35.00 #176 2.0L Rods (set of 4) $70.00 #177 OE Front steel valance $75.00 #178 Riviera wheels (Porsche offset, per) $30.00 #181 901 gear sets (inquire) $75.00 #182 901 Syncro rings (Good used, per) $30.00 #183 Air injection "spider" pipe $25.00 #185 Drivers door panel (blk.) $50.00 #186 D-Jet Fuel Injection Pkg (76MY) $400.00 #187 Center tunnel section (complete w/all guide tubes intact) $150.00 #188 Late bumpers (75-76) per $40.00 #189 Seat cores (one pair, disassembled & boxed) $50.00 #191 OE Rear steel valance $100.00 #192 Heater fan (eng. bay Late) $30.00 #193 Targa top latches (Frt. & R) $30.00 #194 Air diverter's (eng. bay, pair) $30.00 #195 Washer switch (early /4 & /6) $20.00 #196 Speedometer angle drive $35.00 #197 Fresh air hose (plastic, pair) $20.00 #198 Relay board $25.00 #199 Alternator $40.00 #200 Visors (pair) $80.00 #201 Switch, R. window defrost $20.00 #202 Trailing Arm mounts $35.00 #203 Seat adjuster assemblies (per) $40.00 #204 Fog lights (pair, early) $50.00 #205 Back pad, Black (Avg. cond. ) $60.00 what happened to the car?? is it for sale? thanks danny |
rdauenhauer FS: $9.14 & more Oct 2 2008, 03:48 PM
rdauenhauer RE: FS: $9.14 & more Oct 2 2008, 04:01 PM
rdauenhauer RE: FS: $9.14 & more Oct 2 2008, 04:08 PM
rdauenhauer RE: FS: $9.14 & more Oct 2 2008, 04:14 PM
rdauenhauer RE: FS: $9.14 & more Oct 2 2008, 04:23 PM
rdauenhauer RE: FS: $9.14 & more Oct 2 2008, 04:30 PM
rdauenhauer Here are 3 back pad's, decent condition, no v... Oct 2 2008, 06:35 PM
rdauenhauer RE: FS: $9.14 & more Oct 3 2008, 12:25 AM
rdauenhauer RE: FS: $9.14 & more Oct 3 2008, 05:50 PM
rdauenhauer :worship: - Oct 11 2008, 12:13 PM
rdauenhauer :first: Oct 11 2008, 12:37 PM
rdauenhauer :confused: Oct 11 2008, 12:51 PM
rdauenhauer more items:
Dec 2 2008, 06:06 PM
rdauenhauer RE: FS: $9.14 & more Dec 2 2008, 06:11 PM
rdauenhauer More... :wacko: Dec 3 2008, 11:06 PM
rdauenhauer RE: FS: $9.14 & more Dec 10 2008, 11:15 AM
Root_Werks Thanks for all the parts Rich, I already got the t... Apr 23 2010, 08:59 AM
Root_Werks Rich, wanted to say thanks again for all the heate... Jul 15 2010, 09:01 AM
biggy72 Rich,
Thanks for helping me out with all of the ... Aug 15 2010, 10:39 PM
clow I got my valve covers and thermostat in the mail t... Jan 15 2011, 04:52 PM
markb I got my lic plate brackets yesterday. Nicer than ... Apr 16 2011, 10:45 PM
rdomeck Rich the repair panel was much better than describ... May 2 2011, 07:58 AM
Cool914 Thanks for the quarter panels, they were in even b... Jun 27 2011, 10:26 PM
Nie Zu Alt Rich,
The parts arrived today safe and sound - Th... Jun 27 2011, 11:10 PM
sooba_dave Rich-
Thanks so much for the GT lid screen ma... Aug 5 2011, 01:56 PM
rdauenhauer :bump:
Updated & Items added :headbanger: Sep 5 2011, 04:45 PM
bobheinonen
:bump:
... Sep 5 2011, 08:55 PM
bobheinonen
:bump:
... Sep 7 2011, 04:26 PM
Archie
:bump:
... Sep 8 2011, 03:40 PM
LotusJoe #76 Interior Trim Plug set (all necessary to finis... Sep 7 2011, 02:18 PM
MrHyde Parts received today in excellent shape ! Than... Sep 14 2011, 02:23 PM
rdauenhauer :bump:
Wow fell to the 4 pg. :lol: Sep 30 2011, 01:07 PM
Archie
:bump:
Hi Rich. ... Oct 1 2011, 11:22 PM
BarberDave :trophy:
Rich :
I will take th... Oct 2 2011, 07:46 AM
pilothyer Hello Rich...I just wanted to let you know that I ... Oct 5 2011, 08:15 AM
cconcepcion Is #15 drivers side window regulator available? s... Oct 5 2011, 12:33 PM
yeahmag Can I get the thickness measurements off the rotor... Oct 18 2011, 06:34 PM
Bob L. PM Sent Oct 19 2011, 09:26 PM
Bob L. Another PM sent. Oct 23 2011, 10:03 AM
rgalla9146
For sale misc. items. (Pics start in 2nd post ... Oct 28 2011, 08:25 AM
rdauenhauer :confused: is there a question?
EDIT
:D I had... Oct 28 2011, 12:48 PM
rdauenhauer :bump: Oct 30 2011, 09:31 PM
computers4kids Is #6 the wood or plastic version? Was there a pi... Oct 30 2011, 09:52 PM
rdauenhauer
Is #6 the wood or plastic version? Was there a p... Oct 30 2011, 10:22 PM
Garold Shaffer PM sent Oct 31 2011, 11:22 AM
914werke PM sent Nov 9 2011, 11:48 PM
rdauenhauer :santa: :bump: Nov 20 2011, 01:14 AM
trfrick PM sent for the heater flapper Nov 23 2011, 08:53 PM
Deep6 I will take the 1.7L D-jet FI harness #174 $4... Nov 26 2011, 02:11 PM
Deep6
I will take the 1.7L D-jet FI harness #174 ... Nov 27 2011, 05:23 PM
914brokenfilms #40 speaker grills - still available? Condition? P... Nov 27 2011, 09:49 PM
rdauenhauer
I will take the 1.7L D-jet FI harness #174 ... Nov 28 2011, 11:59 AM
rdauenhauer :santa: :bump: :wavebye: Dec 1 2011, 12:01 AM
rdauenhauer :rolleyes: Dec 5 2011, 11:32 PM
rdauenhauer :hugme: :santa: :wavebye:
:bump: Dec 13 2011, 12:21 PM
arg
:bump:
would ... Dec 18 2011, 10:16 AM
neyen14 Thanks Richard, the plates arrived and I dig ... Dec 14 2011, 08:56 AM
bryanf The door handle arrived just as I was pulling and ... Dec 14 2011, 12:01 PM
Justin Fischer #177 OE Front steel valance $75.00
Any pics... Dec 17 2011, 08:16 PM
rdauenhauer :santa: :drooley: Dec 21 2011, 11:58 AM
neyen14 Thanks Richard... Exellent!... again! :D Dec 22 2011, 06:06 PM
rdauenhauer :headbanger: Jan 3 2012, 05:48 PM
Archie
:headbanger:
Hi Rich,
Archie here! Just g... Jan 8 2012, 11:05 PM
rdauenhauer :wub:
:wavebye: Jan 11 2012, 11:08 PM
rdauenhauer Updated Jan 13 2012, 01:06 PM
Strudelwagon Hi Rich, I just sent a paypal for the seat belt hi... Jan 13 2012, 01:50 PM
Strudelwagon
Hi Rich, I just sent a paypal for the seat belt h... Jan 20 2012, 05:41 PM
Wegeng_Haus Rich- I just recieved the half shaft. It looks g... Jan 15 2012, 10:02 AM
Tomhilmes Hi. I need a fresh air box complete with motor, d... Jan 16 2012, 01:12 AM
ndfrigi Hi Sir,
Still have the sunvisor? Is it include th... Jan 21 2012, 02:22 PM
MassTeener
For sale misc. items. (Pics start in 2nd post ... Mar 21 2012, 09:06 PM
rdauenhauer
what happened to the car?? is it for sale? thank... Jan 21 2012, 02:58 PM
pete000 PM Sent Jan 21 2012, 05:41 PM
70Sixer Do you have a very good condition short (25mm scre... Jan 21 2012, 11:34 PM
rgolia
For sale misc. items. (Pics start in 2nd post ... Jan 24 2012, 10:17 AM
rgolia Do you still have the fog lights. If not I am loo... Jan 24 2012, 10:19 AM
rdauenhauer Reply's sent, items shipped. Jan 24 2012, 05:53 PM
gecko I am interested in, if you still have.
#133 Motor... Jan 28 2012, 01:26 PM
DC1975-42.0 I need a CV joint or a complete half shaft for my ... Feb 1 2012, 01:01 PM
euro911 Rich,
I'll take these for the my fresh air bo... Feb 2 2012, 04:33 PM
Tomhilmes Rich,
Thanks again for the help. The fresh air b... Feb 9 2012, 08:25 PM
Tomhilmes Rich,
Thanks again for the help. The fresh air b... Feb 9 2012, 08:26 PM
Ed_F Rich, your PM box is full. I'm interested in t... Feb 12 2012, 04:27 PM
bryanf Rich,
I got the calipers and installed them this ... Feb 13 2012, 11:30 AM
rdauenhauer Sorry folks Ive been haveing some...Technical diff... Feb 13 2012, 03:29 PM
914werke PM sent :bump: Feb 18 2012, 08:53 PM
flash914 Do you still have the block/ tool for adjusting tr... Feb 19 2012, 12:45 AM
rph20355 I'm interested in one of the .5 shafts (#130).... Feb 20 2012, 11:27 PM
sbruzek I'll buy the relay board. Do you have a rear... Feb 25 2012, 07:31 PM
rdauenhauer :bump: Feb 28 2012, 02:37 PM
rgolia Do you still have the dash mount washer switch? Feb 28 2012, 05:56 PM
rdauenhauer To the TOP! Mar 1 2012, 12:24 PM
markyb PM sent regarding the rain tray drain tubes.... Mar 9 2012, 08:54 AM
Bob L. P.M. sent re: FI kit Mar 13 2012, 09:39 AM
jcambo7 #88 Carb Fuel Pump (Faucet style)$20.00
Coul... Mar 13 2012, 11:44 AM
rdauenhauer :bump: Mar 21 2012, 11:36 AM
tim_nd PM sent regarding those fine looking seat belt lat... Mar 21 2012, 03:46 PM
rdauenhauer STILL have a fuel pump for carbs?? Thanks
Sorry... Mar 21 2012, 10:02 PM
rgolia I will take #32 turn signal buckets...if you have ... Mar 25 2012, 07:49 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:22 AM |
