| euro911 |
Jan 21 2012, 02:39 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
I have a 15mm sway bar that I'd like to install on the '75 while we have the fuel tank out (replacing the plastic lines with SS lines).
I've never replaced bushings before, so I'm looking for some expertise from you guys. The new Pelican bushings appear to be different than the OEM ones we pulled off. The old bushings had a linear slice that allowed me to remove them. The new bushings are a harder compound and not sliced. Do I slice them with a hacksaw? or band saw? ... or do I place them in boiling hot water and press them on? (IMG:style_emoticons/default/confused24.gif) I'm sitting here twiddling my thumbs until I get a good answer ... (IMG:style_emoticons/default/popcorn[1].gif) |
| luskesq |
Jan 22 2012, 11:09 PM
Member ![]() ![]() Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
The Pelican site says in part in the section on the sway bar bushings: "Note: Front Cup Bushings must be slit on one side to fit around bar."
Keith |
euro911 Question: Front Anti-SwayBar Bushings Jan 21 2012, 02:39 PM
Racer Chris I think you have to split them into two pieces. Jan 21 2012, 03:32 PM
flash914 I just sliced mine with a box cutter *** CAREFUL**... Jan 21 2012, 03:47 PM
Eric_Shea Slice'em Jan 21 2012, 08:20 PM
VOX you guys cut them? really!? i had no idea that... Jan 22 2012, 01:00 AM
Eric_Shea Talking about different bushings VOX... Jan 22 2012, 01:04 AM
euro911 Yep, these are the bushings that go around the tor... Jan 22 2012, 01:20 AM
VOX oh ok, sorry for the mistake. i should take a look... Jan 22 2012, 01:27 AM
Dave_Darling I did not slice 'em. I pushed the square end ... Jan 22 2012, 03:18 PM
Eric_Shea I honestly don't know how that's possible ... Jan 22 2012, 07:08 PM
euro911 Yeah :confused: ... the old adage "you can... Jan 22 2012, 08:08 PM
Dave_Darling I am fairly sure I did. The bushings are somewhat... Jan 22 2012, 09:19 PM
scott_in_nh
I am fairly sure I did. The bushings are somewha... Aug 6 2013, 06:35 AM
euro911 I didn't order them from their on-line catalog... Jan 22 2012, 11:20 PM
jesiv They are split from the factory
Regards
James May 14 2013, 07:03 PM
jesiv These are available from Porsche now for $15
... May 14 2013, 07:06 PM
Scott S Is this the same process for aftermarket (Weltmeis... May 15 2013, 01:02 PM
euro911 If they look like they're gonna be tough getti... Aug 5 2013, 10:56 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th June 2026 - 06:54 AM |
