> Question: Front Anti-SwayBar Bushings
euro911
post Jan 21 2012, 02:39 PM
I have a 15mm sway bar that I'd like to install on the '75 while we have the fuel tank out (replacing the plastic lines with SS lines).
I've never replaced bushings before, so I'm looking for some expertise from you guys.
The new Pelican bushings appear to be different than the OEM ones we pulled off.
The old bushings had a linear slice that allowed me to remove them. The new bushings are a harder compound and not sliced.
Do I slice them with a hacksaw? or band saw? ... or do I place them in boiling hot water and press them on? (IMG:style_emoticons/default/confused24.gif)
I'm sitting here twiddling my thumbs until I get a good answer ... (IMG:style_emoticons/default/popcorn[1].gif)
euro911
post Jan 22 2012, 11:20 PM
I didn't order them from their on-line catalog, so I didn't read any notes about their installation ... I just called Glenn and let him know what I needed. I should go the their tech article site to see if they have a 'How To' posted (IMG:style_emoticons/default/idea.gif)
I'll probably 'slit' them as recommended. Thanks ...
EDIT
They DO have a tech article: http://www.pelicanparts.com/techarticles/9...ont_swaybar.htm
But get this ... they don't say anything about 'slitting' the bushings - they state they pushed the bar through them (IMG:style_emoticons/default/blink.gif)
"After you have installed the mounts for the sway bar, you then need to install the bar itself. If I remember correctly, it was very difficult to get the bar into the bushings. You basically need to attach the mounts that sandwich the bushing to either side of the car, and then slide the bar through. Leave the nuts pretty loose, as you don't want to compress the bushing while you're sliding the bar through. Luckily, you can put the bar through the bushing on one side before you install it on the car. It's a wise idea to use new bushings for this process, because once the bar is in, it is difficult to take out. This process is a pain because the diameter of the end of the bar is bigger than the bar itself. Once you have the bar through both sets of bushings and mounted to the car, then tighten the mounts."
euro911   Question: Front Anti-SwayBar Bushings   Jan 21 2012, 02:39 PM
Racer Chris   I think you have to split them into two pieces.   Jan 21 2012, 03:32 PM
flash914   I just sliced mine with a box cutter *** CAREFUL**...   Jan 21 2012, 03:47 PM
Eric_Shea   Slice'em   Jan 21 2012, 08:20 PM
VOX   you guys cut them? really!? i had no idea that...   Jan 22 2012, 01:00 AM
Eric_Shea   Talking about different bushings VOX...   Jan 22 2012, 01:04 AM
euro911   Yep, these are the bushings that go around the tor...   Jan 22 2012, 01:20 AM
VOX   oh ok, sorry for the mistake. i should take a look...   Jan 22 2012, 01:27 AM
Dave_Darling   I did not slice 'em. I pushed the square end ...   Jan 22 2012, 03:18 PM
Eric_Shea   I honestly don't know how that's possible ...   Jan 22 2012, 07:08 PM
euro911   Yeah :confused: ... the old adage "you can...   Jan 22 2012, 08:08 PM
Dave_Darling   I am fairly sure I did. The bushings are somewhat...   Jan 22 2012, 09:19 PM
scott_in_nh   I am fairly sure I did. The bushings are somewha...   Aug 6 2013, 06:35 AM
luskesq   The Pelican site says in part in the section on th...   Jan 22 2012, 11:09 PM
euro911   I didn't order them from their on-line catalog...   Jan 22 2012, 11:20 PM
jesiv   They are split from the factory Regards James   May 14 2013, 07:03 PM
jesiv   These are available from Porsche now for $15 ...   May 14 2013, 07:06 PM
Scott S   Is this the same process for aftermarket (Weltmeis...   May 15 2013, 01:02 PM
euro911   If they look like they're gonna be tough getti...   Aug 5 2013, 10:56 PM
- Lo-Fi Version Time is now: 17th June 2026 - 06:54 AM
