need pics of 5 lug 15x7 cookie cutters on narrow body, 205x50x15 seems to be the best size - widths vary by brand |
jimkelly |
Nov 15 2011, 06:22 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
pic
i measured backspace and got 4.5" - figured it would be more. Attached image(s) |
BK911 |
Jan 27 2012, 10:49 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Just out of curiousity...
Why run 15x7s with 205.50s instead of 15x6s with 205.50s? Tire patch should be almost identical. Is it all the advantages of a heavier wheel? (IMG:style_emoticons/default/smile.gif) |
campbellcj |
Jan 27 2012, 11:08 AM
I can't Re Member Group: Members Posts: 4,549 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Within reason, it is better to not have the sidewalls "pinched" inwards as is the case with a 205mm tire on a 6" (152mm") rim. The identical tire will perform better on a wheel that is optimally sized versus one that is too narrow, or too wide.
There is of course a weight differential though. Just out of curiousity... Why run 15x7s with 205.50s instead of 15x6s with 205.50s? Tire patch should be almost identical. Is it all the advantages of a heavier wheel? (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 10:48 AM |
