Headlight Stuck Closed, locked up and f'd up |
7TPorsh |
Aug 22 2011, 11:11 AM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
One of my lights is stuck in the closed position. relay is good, fuse is good. Was working then stopped at some point.
Not lined up to well. Any way to take it apart whiloe closed/ The crank manual open feature is BS; never worked. |
flash914 |
Jan 29 2012, 01:43 PM
Member Group: Members Posts: 124 Joined: 1-January 11 From: littlerock CA Member No.: 12,554 Region Association: Southern California |
The knobs are left hand thread. Bruse Stone can sell you a couple if you need more. Look at the wiring diagrams on pelican parts. Three wires on top Red Gray Green/black. Red is power for relay, Green/black is down, Gray is up. When you pull the switch Gray goes hot and the motor spin untill the switch inside the gearbox opens. Look for a open in the gray wire. Check for power on both side of the car and compare side to side. Gordon
Lo-Fi Version | Time is now: 9th June 2024 - 08:54 PM |
