> Rear Quarter Panel Repair Ideas
TargaToy
post Feb 5 2012, 08:16 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO-
So once again I find myself going where the sun don't shine.
Eventually, I plan to post the receipt from where the body shop charged the interim owner for "replacing quarter panel"...but that's fun for another day.
Here's my question: Am I correct that, from the factory, the little void in the point at the rear of the quarter panel (above the tail light) is left empty--or full of spray foam--and that there's a very large glob of seam sealer supposedly preventing tire-slung moisture from finding the foam?
I had to open mine up all the way and I'm toying with actually welding in a custom baffle in front of that pointed tip so that I could seal it up tight from the front side of the baffle. I would do this as part of the process when I fit in the new fender section.
What I want to do is make sure moisture can't get into that rear point and fester.
Anybody who's reworked the rearmost part of the fender/light socket, what have you done???
rick 918-S
post Feb 5 2012, 09:01 PM
Hey nice rack! -Celette
I'm of two minds here when it comes to that pocket. I could agree with sir Andy if I lived on the gold coast unless you drive near the beach and salt water. That is one of the most diffecult areas to clean out and derust without cutting it open like yours. The trouble is over time the calk will release and moisture gets between the calk and the panel. I think todays urothane seam sealers are far superior to what Porsche used in the early 70's. I would take all the proper steps to etch, seal and paint the inside and then reseal the pocket with modern seam sealer. But that's just me.
TargaToy
post Feb 5 2012, 09:19 PM
QUOTE(rick 918-S @ Feb 5 2012, 10:01 PM) *
The Ospho cured over night so the rust looks "halted" now. I can get some primer on it now but I'll be welding all around the general vicinity when the fender skin goes on--not good for sealer. Are you suggesting making the repairs, maybe some more Ospho, spraying primer/paint into the point, and then packing it back full with sealer?
By the way, for this and for other areas like inside jack posts, does anybody sell a rattle can paint with a red tube like you get with starter fluid/WD-40?. I was thinking that if I had a small hole on the inside of the trunk, I could get some decent amounts of paint sprayed into the point where I couldn't reach otherwise.
TargaToy   Rear Quarter Panel Repair Ideas   Feb 5 2012, 08:16 PM
SirAndy   I have had very good results with leaving that are...   Feb 5 2012, 08:37 PM
TargaToy   I have had very good results with leaving that ar...   Feb 5 2012, 09:02 PM
rick 918-S   I'm of two minds here when it comes to that po...   Feb 5 2012, 09:01 PM
TargaToy   I'm of two minds here when it comes to that p...   Feb 5 2012, 09:19 PM
kertwerks   By the way, for this and for other areas like insi...   Feb 6 2012, 07:51 PM
TargaToy   By the way, for this and for other areas like ins...   Feb 6 2012, 11:18 PM
Eric_Shea   https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-as...   Feb 6 2012, 11:33 PM
TargaToy   I can't project myself into the future to kno...   Feb 7 2012, 08:47 PM
euro911   Eric, is that a rust converter, or paint? That loo...   Feb 6 2012, 11:52 PM
ThePaintedMan   Eric, is that a rust converter, or paint? That lo...   Feb 7 2012, 12:37 AM
Eric_Shea   Hey Mark, Check this out... http://www.eastwood....   Feb 7 2012, 12:34 AM
euro911   I just checked out the Evapo-Rust site and watched...   Feb 7 2012, 01:25 AM
ThePaintedMan   Oops! My mistake Mark. What about the popular ...   Feb 7 2012, 01:45 AM
Eric_Shea   Take a look at the first picture I posted. The ...   Feb 7 2012, 09:14 PM
TargaToy   Take a look at the first picture...Now look at ...   Feb 7 2012, 09:56 PM
Socalandy   I used it in my longs and everywhere I could feed ...   Feb 7 2012, 10:07 PM
euro911   Hey Andy, in your last pic, did you spray the East...   Feb 8 2012, 12:01 AM
burton73   I put the Eastwood stuff into the longs through th...   Feb 8 2012, 06:35 PM
Socalandy   I used the repair opening to clean out and spray i...   Feb 8 2012, 11:54 PM
euro911   The Eastwood product looks like it does the trick....   Feb 9 2012, 01:23 AM
jimkelly   so the concensus is to - spray ospho into the long...   Sep 29 2012, 08:51 AM
charliew   I like ospho and use it on almost everything BUT. ...   Sep 29 2012, 09:15 AM
TargaToy   Today, I cleaned up a nose section which will even...   Sep 29 2012, 04:37 PM
- Lo-Fi Version Time is now: 19th July 2025 - 10:13 AM
