> Wiper switch differences, trying to add an elec. washer switch
peteyd
post Feb 6 2012, 10:06 PM
I am trying to figure out what I have here. I noticed that there are two different wiper switches available. 70-72 and 73-76.
This is the one that is in the best condition.
Notice that it only has four pins on the left side.
I have already attached a switch that I got from davep, which will trigger my electric washer pump that I plan to install.
This is the second one that I have. Being in worse condition out of the two.
It has five pins on the left side. The extra one being a brown, which is ground correct?
The switch is also different in that the plunger that would activate the washer fluid has an electrical contact
I am running a wiring harness from a 72 car. Which switch do I need to use? Am i missing pieces from the first switch maybe?
Im stumped here...
Pete
post Feb 6 2012, 10:34 PM
Resident German
QUOTE(peteyd @ Feb 6 2012, 08:06 PM) *
I'm pretty sure the wires you need weren't part of the main harness and switch until '73/'74.
So, even if you used the later switch portion, your harness would still be missing the correct wires.
It's been a while, so a may be wrong about this ...
peteyd   Wiper switch differences   Feb 6 2012, 10:06 PM
SirAndy   I am running a wiring harness from a 72 car. Which...   Feb 6 2012, 10:34 PM
jim_hoyland   See: http://www.914world.com/bbs2/index.php?sho.....   Feb 7 2012, 07:49 AM
peteyd   See: http://www.914world.com/bbs2/index.php?sho....   Feb 7 2012, 09:25 AM
Valy   I've done a lot of research on this topic. Her...   Feb 7 2012, 12:19 PM
SirAndy   2. The 5 wire switch adds the timed delay relay ...   Feb 7 2012, 12:29 PM
Valy   2. The 5 wire switch adds the timed delay relay...   Feb 7 2012, 01:14 PM
SirAndy   If you count on the relay to power the pump when y...   Feb 7 2012, 02:16 PM
Valy   If you count on the relay to power the pump when ...   Feb 7 2012, 06:06 PM
jkb944t   I've done a lot of research on this topic. He...   Jun 20 2018, 10:30 AM
peteyd   Great! Thank you Valy for all that info. I no...   Feb 7 2012, 02:36 PM
Cap'n Krusty   A switch from a '77 924, Rabbit, or Scirocco w...   Feb 7 2012, 02:56 PM
peteyd   A switch from a '77 924, Rabbit, or Scirocco ...   Feb 7 2012, 05:35 PM
Valy   A switch from a '77 924, Rabbit, or Scirocco ...   Feb 7 2012, 05:47 PM
Krieger   There are reproductions available. Not great but...   Feb 28 2012, 10:37 PM
Valy   There are reproductions available. Not great bu...   Feb 28 2012, 11:01 PM
Krieger   Which fuse Burns? -5th one from right, it has the ...   Feb 29 2012, 07:59 PM
Valy   Here is the best solution in my opinion, using the...   Feb 7 2012, 06:16 PM
peteyd   Here is the best solution in my opinion, using th...   Feb 7 2012, 07:32 PM
Valy   Here is the best solution in my opinion, using t...   Feb 7 2012, 08:10 PM
Eric_Shea   Update. Many Thanks to Valy for the countless e-m...   Feb 28 2012, 01:01 PM
Bartlett 914   I did a little research on this as well. If you wa...   Feb 29 2012, 08:35 AM
Eric_Shea   Interesting Mark. So if I pull my stalk and activ...   Feb 29 2012, 09:25 AM
Valy   Interesting Mark. So if I pull my stalk and acti...   Feb 29 2012, 09:44 AM
Bartlett 914   Interesting Mark. So if I pull my stalk and acti...   Feb 29 2012, 01:54 PM
Valy   DELETED   Feb 29 2012, 02:26 PM
Eric_Shea   Whew...   Feb 29 2012, 10:01 AM
Bartlett 914   IIRC the brown white wire to the intermittent rela...   Feb 29 2012, 02:23 PM
Valy   Try this: ignition off. Put the which in high spe...   Feb 29 2012, 08:15 PM
Krieger   I put a 16 amp in and put the wiper switch all the...   Feb 29 2012, 08:55 PM
Valy   I put a 16 amp in and put the wiper switch all th...   Feb 29 2012, 09:17 PM
Krieger   So I am measuring between the ground terminal on t...   Feb 29 2012, 09:55 PM
Krieger   Wipers didn't move. I am going to pull out the...   Feb 29 2012, 09:27 PM
Krieger   Plug   Feb 29 2012, 10:14 PM
Valy   That's the signal switch connector. Look at th...   Feb 29 2012, 10:26 PM
Krieger   Doh! I figured that out and this is what I...   Feb 29 2012, 10:34 PM
Valy   OK. Green/white shows that your wipers are probabl...   Feb 29 2012, 10:44 PM
Krieger   black/purple 10.7 black/blue 10.2   Feb 29 2012, 10:53 PM
Krieger   Just got an old wiper switch of unknown origin. P...   Feb 29 2012, 11:03 PM
Valy   Just got an old wiper switch of unknown origin. ...   Mar 1 2012, 12:42 AM
Eric_Shea   Andy... It's your switch. ;) Happy to help...   Feb 29 2012, 11:19 PM
Valy   Eric, I knew you're going to master it! ;...   Mar 1 2012, 12:36 AM
jt914-6   For those who own a '70-71 (I think that is th...   Mar 1 2012, 07:09 AM
Krieger   I'l get back into this tonight when I get home...   Mar 1 2012, 09:57 AM
Krieger   Hey, I'm at it again. Here are some observat...   Mar 1 2012, 09:16 PM
Valy   Your backdate column is grounded. Check from somet...   Mar 1 2012, 09:37 PM
Krieger   There was a small "protrusion" I filed ...   Mar 1 2012, 10:01 PM
Krieger   The protrusion was similar to the top right of you...   Mar 1 2012, 10:07 PM
Valy   :trophy: Happy to help :)   Mar 1 2012, 11:15 PM
Valy   Positive (99% sure but I can't check right now...   Jun 20 2018, 10:28 PM
Valy   Yes, it's 12v.   Jun 21 2018, 01:12 AM
- Lo-Fi Version Time is now: 19th November 2026 - 06:02 PM
