| peteyd |
Feb 6 2012, 10:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 744 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
I am trying to figure out what I have here. I noticed that there are two different wiper switches available. 70-72 and 73-76.
This is the one that is in the best condition. Notice that it only has four pins on the left side. ![]() I have already attached a switch that I got from davep, which will trigger my electric washer pump that I plan to install. ![]() This is the second one that I have. Being in worse condition out of the two. It has five pins on the left side. The extra one being a brown, which is ground correct? ![]() The switch is also different in that the plunger that would activate the washer fluid has an electrical contact ![]() I am running a wiring harness from a 72 car. Which switch do I need to use? Am i missing pieces from the first switch maybe? Im stumped here... Pete |
| peteyd |
Feb 7 2012, 09:25 AM
See: http://www.914world.com/bbs2/index.php?sho...l=wiper*++wire* This has some helpful info and diagrams. (IMG:style_emoticons/default/smile.gif) This is somewhat helpful, but it still does not distinguish which is the early and late wiper switch. I am assuming now that the one without the extra pin is the earlier one. Can someone still confirm this? |
peteyd Wiper switch differences Feb 6 2012, 10:06 PM
SirAndy I am running a wiring harness from a 72 car. Which... Feb 6 2012, 10:34 PM
jim_hoyland See: http://www.914world.com/bbs2/index.php?sho..... Feb 7 2012, 07:49 AM
Valy I've done a lot of research on this topic. Her... Feb 7 2012, 12:19 PM
2. The 5 wire switch adds the timed delay relay ... Feb 7 2012, 12:29 PM
Valy
2. The 5 wire switch adds the timed delay relay... Feb 7 2012, 01:14 PM
SirAndy If you count on the relay to power the pump when y... Feb 7 2012, 02:16 PM
Valy
If you count on the relay to power the pump when ... Feb 7 2012, 06:06 PM
jkb944t
I've done a lot of research on this topic. He... Jun 20 2018, 10:30 AM
peteyd Great!
Thank you Valy for all that info. I no... Feb 7 2012, 02:36 PM
Cap'n Krusty A switch from a '77 924, Rabbit, or Scirocco w... Feb 7 2012, 02:56 PM
peteyd
A switch from a '77 924, Rabbit, or Scirocco ... Feb 7 2012, 05:35 PM
Valy
A switch from a '77 924, Rabbit, or Scirocco ... Feb 7 2012, 05:47 PM
Krieger
There are reproductions available. Not great but... Feb 28 2012, 10:37 PM
Valy
There are reproductions available. Not great bu... Feb 28 2012, 11:01 PM
Krieger Which fuse Burns? -5th one from right, it has the ... Feb 29 2012, 07:59 PM
Valy Here is the best solution in my opinion, using the... Feb 7 2012, 06:16 PM
peteyd
Here is the best solution in my opinion, using th... Feb 7 2012, 07:32 PM
Valy
Here is the best solution in my opinion, using t... Feb 7 2012, 08:10 PM
Eric_Shea Update.
Many Thanks to Valy for the countless e-m... Feb 28 2012, 01:01 PM
Bartlett 914 I did a little research on this as well. If you wa... Feb 29 2012, 08:35 AM
Eric_Shea Interesting Mark. So if I pull my stalk and activ... Feb 29 2012, 09:25 AM
Valy
Interesting Mark. So if I pull my stalk and acti... Feb 29 2012, 09:44 AM
Bartlett 914
Interesting Mark. So if I pull my stalk and acti... Feb 29 2012, 01:54 PM
Valy DELETED Feb 29 2012, 02:26 PM
Eric_Shea Whew... Feb 29 2012, 10:01 AM
Bartlett 914 IIRC the brown white wire to the intermittent rela... Feb 29 2012, 02:23 PM
Valy Try this:
ignition off. Put the which in high spe... Feb 29 2012, 08:15 PM
Krieger I put a 16 amp in and put the wiper switch all the... Feb 29 2012, 08:55 PM
Valy
I put a 16 amp in and put the wiper switch all th... Feb 29 2012, 09:17 PM
Krieger So I am measuring between the ground terminal on t... Feb 29 2012, 09:55 PM
Krieger Wipers didn't move. I am going to pull out the... Feb 29 2012, 09:27 PM
Krieger Plug Feb 29 2012, 10:14 PM
Valy That's the signal switch connector. Look at th... Feb 29 2012, 10:26 PM
Krieger Doh! I figured that out and this is what I... Feb 29 2012, 10:34 PM
Valy OK.
Green/white shows that your wipers are probabl... Feb 29 2012, 10:44 PM
Krieger black/purple 10.7
black/blue 10.2 Feb 29 2012, 10:53 PM
Krieger Just got an old wiper switch of unknown origin. P... Feb 29 2012, 11:03 PM
Valy
Just got an old wiper switch of unknown origin. ... Mar 1 2012, 12:42 AM
Eric_Shea Andy... It's your switch. ;)
Happy to help... Feb 29 2012, 11:19 PM
Valy Eric, I knew you're going to master it! ;... Mar 1 2012, 12:36 AM
jt914-6 For those who own a '70-71 (I think that is th... Mar 1 2012, 07:09 AM
Krieger I'l get back into this tonight when I get home... Mar 1 2012, 09:57 AM
Krieger Hey, I'm at it again.
Here are some observat... Mar 1 2012, 09:16 PM
Valy Your backdate column is grounded. Check from somet... Mar 1 2012, 09:37 PM
Krieger There was a small "protrusion" I filed ... Mar 1 2012, 10:01 PM
Krieger The protrusion was similar to the top right of you... Mar 1 2012, 10:07 PM
Valy :trophy:
Happy to help :) Mar 1 2012, 11:15 PM
Valy Positive (99% sure but I can't check right now... Jun 20 2018, 10:28 PM
Valy Yes, it's 12v. Jun 21 2018, 01:12 AM![]() ![]() |
Lo-Fi Version | Time is now: 19th November 2026 - 06:02 PM |
