> Rear Quarter Panel Repair Ideas
TargaToy
post Feb 5 2012, 08:16 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO-
So once again I find myself going where the sun don't shine.
Eventually, I plan to post the receipt from where the body shop charged the interim owner for "replacing quarter panel"...but that's fun for another day.
Here's my question: Am I correct that, from the factory, the little void in the point at the rear of the quarter panel (above the tail light) is left empty--or full of spray foam--and that there's a very large glob of seam sealer supposedly preventing tire-slung moisture from finding the foam?
I had to open mine up all the way and I'm toying with actually welding in a custom baffle in front of that pointed tip so that I could seal it up tight from the front side of the baffle. I would do this as part of the process when I fit in the new fender section.
What I want to do is make sure moisture can't get into that rear point and fester.
Anybody who's reworked the rearmost part of the fender/light socket, what have you done???
Eric_Shea
post Feb 6 2012, 11:33 PM
PMB Performance
(IMG:https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash4/319247_2451388329971_1409883264_2920453_1189956943_n.jpg)
(IMG:https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash4/321269_2451388609978_1409883264_2920454_1309828460_n.jpg)
(IMG:https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash4/295854_2451389209993_1409883264_2920456_29285596_n.jpg)
I can't project myself into the future to know if it works but, it really is a trick bottle/coating method. I did this to my 911 rear torsion tubes back in September
TargaToy
post Feb 7 2012, 08:47 PM
QUOTE(Eric_Shea @ Feb 7 2012, 12:33 AM) *
Can the hose/nozzle be cleaned or is the rig toast after using it the first time? In other words, is this something I would save up and do all the troubled areas at once because the stuff will harden up in the tube and not be useful on day two? Can you clear it like a normal rattle can?
TargaToy   Rear Quarter Panel Repair Ideas   Feb 5 2012, 08:16 PM
SirAndy   I have had very good results with leaving that are...   Feb 5 2012, 08:37 PM
TargaToy   I have had very good results with leaving that ar...   Feb 5 2012, 09:02 PM
rick 918-S   I'm of two minds here when it comes to that po...   Feb 5 2012, 09:01 PM
TargaToy   I'm of two minds here when it comes to that p...   Feb 5 2012, 09:19 PM
kertwerks   By the way, for this and for other areas like insi...   Feb 6 2012, 07:51 PM
TargaToy   By the way, for this and for other areas like ins...   Feb 6 2012, 11:18 PM
Eric_Shea   https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-as...   Feb 6 2012, 11:33 PM
TargaToy   I can't project myself into the future to kno...   Feb 7 2012, 08:47 PM
euro911   Eric, is that a rust converter, or paint? That loo...   Feb 6 2012, 11:52 PM
ThePaintedMan   Eric, is that a rust converter, or paint? That lo...   Feb 7 2012, 12:37 AM
Eric_Shea   Hey Mark, Check this out... http://www.eastwood....   Feb 7 2012, 12:34 AM
euro911   I just checked out the Evapo-Rust site and watched...   Feb 7 2012, 01:25 AM
ThePaintedMan   Oops! My mistake Mark. What about the popular ...   Feb 7 2012, 01:45 AM
Eric_Shea   Take a look at the first picture I posted. The ...   Feb 7 2012, 09:14 PM
TargaToy   Take a look at the first picture...Now look at ...   Feb 7 2012, 09:56 PM
Socalandy   I used it in my longs and everywhere I could feed ...   Feb 7 2012, 10:07 PM
euro911   Hey Andy, in your last pic, did you spray the East...   Feb 8 2012, 12:01 AM
burton73   I put the Eastwood stuff into the longs through th...   Feb 8 2012, 06:35 PM
Socalandy   I used the repair opening to clean out and spray i...   Feb 8 2012, 11:54 PM
euro911   The Eastwood product looks like it does the trick....   Feb 9 2012, 01:23 AM
jimkelly   so the concensus is to - spray ospho into the long...   Sep 29 2012, 08:51 AM
charliew   I like ospho and use it on almost everything BUT. ...   Sep 29 2012, 09:15 AM
TargaToy   Today, I cleaned up a nose section which will even...   Sep 29 2012, 04:37 PM
- Lo-Fi Version Time is now: 19th July 2025 - 10:14 AM
