TargaToy |
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- ![]() ![]() ![]() Group: Members Posts: 713 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region ![]() ![]() |
So once again I find myself going where the sun don't shine.
Eventually, I plan to post the receipt from where the body shop charged the interim owner for "replacing quarter panel"...but that's fun for another day. Here's my question: Am I correct that, from the factory, the little void in the point at the rear of the quarter panel (above the tail light) is left empty--or full of spray foam--and that there's a very large glob of seam sealer supposedly preventing tire-slung moisture from finding the foam? I had to open mine up all the way and I'm toying with actually welding in a custom baffle in front of that pointed tip so that I could seal it up tight from the front side of the baffle. I would do this as part of the process when I fit in the new fender section. What I want to do is make sure moisture can't get into that rear point and fester. Anybody who's reworked the rearmost part of the fender/light socket, what have you done??? ![]() ![]() |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
QUOTE Can the hose/nozzle be cleaned or is the rig toast after using it the first time? Take a look at the first picture I posted. The hose assembly is in that bag. The round white part is the button/nozzle. Now look at the last picture. That's me spraying brake cleaner through it. You just pull the button/nozzle off the sealer can and put it on a solvent can and it's like new again. |
TargaToy |
QUOTE Can the hose/nozzle be cleaned or is the rig toast after using it the first time? Take a look at the first picture...Now look at the last picture. That's me spraying brake cleaner through it. You just pull the button/nozzle off the sealer can and put it on a solvent can and it's like new again. I'm liking this a lot. |
Lo-Fi Version | Time is now: 19th July 2025 - 10:12 AM |
