Gradually running rougher, And tailpipe popping |
jeffdon |
Feb 12 2012, 10:27 AM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
So, My carbed, cammed, malloried 2056 has been steller for about 6k miles. Then on a run up to Santa Rosa it started feeling less "crisp" on acceleration, and is popping out the tailpipe when cruising along. Not loud bangs, kinda softly doing it. Getting also a bit of snorting out the carbs on start up. Going to crawl under today and check for exhaust leaks (SS exchangers).
What else should I check? Valves? Timing? Ignition circuit? Also, as an engine wears in and you start putting some miles on it, can it change in such a way that would require re-evaluating your jetting? |
TheCabinetmaker |
Feb 12 2012, 12:06 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
gradual deterioration of power would point me towards a dirty carb, decreasing fuel pressure (maybe due to a dirty filter), weakening spark, or worse, losing compression. did you do a compression check when fresh? If so, do another one and compare.
Lo-Fi Version | Time is now: 10th June 2024 - 03:01 PM |
