Gradually running rougher, And tailpipe popping |
jeffdon |
Feb 12 2012, 10:27 AM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
So, My carbed, cammed, malloried 2056 has been steller for about 6k miles. Then on a run up to Santa Rosa it started feeling less "crisp" on acceleration, and is popping out the tailpipe when cruising along. Not loud bangs, kinda softly doing it. Getting also a bit of snorting out the carbs on start up. Going to crawl under today and check for exhaust leaks (SS exchangers).
What else should I check? Valves? Timing? Ignition circuit? Also, as an engine wears in and you start putting some miles on it, can it change in such a way that would require re-evaluating your jetting? |
jeffdon |
Feb 12 2012, 12:46 PM
Turned in the idle mixture screws, and it seems to have its old crispness back.
Plugs at idle look like this....what say all yee ole plug reading pros? |
Lo-Fi Version | Time is now: 10th June 2024 - 02:14 AM |
