Gradually running rougher, And tailpipe popping |
jeffdon |
Feb 12 2012, 10:27 AM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
So, My carbed, cammed, malloried 2056 has been steller for about 6k miles. Then on a run up to Santa Rosa it started feeling less "crisp" on acceleration, and is popping out the tailpipe when cruising along. Not loud bangs, kinda softly doing it. Getting also a bit of snorting out the carbs on start up. Going to crawl under today and check for exhaust leaks (SS exchangers).
What else should I check? Valves? Timing? Ignition circuit? Also, as an engine wears in and you start putting some miles on it, can it change in such a way that would require re-evaluating your jetting? |
TheCabinetmaker |
Feb 12 2012, 12:29 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Ha! that would definitely cause a weak spark
struckn |
Feb 12 2012, 12:53 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
Porschef |
Feb 12 2012, 01:02 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
[/quote]
Look for arcing from the plug wires and the connection from Coil to Dizzy and plugs also. If you have electronic ignition (i.e. pertronix) Gap your plugs .040 - .050. [/quote] I swapped out to Pertronix, but didn't read any mention of changing the gap. Is this your experience to find it to run better with the .040-.050 setting? Thanks |
jeffdon |
Feb 12 2012, 01:07 PM
[quote name='Porschef' date='Feb 12 2012, 11:02 AM' post='1623529']
[/quote] Look for arcing from the plug wires and the connection from Coil to Dizzy and plugs also. If you have electronic ignition (i.e. pertronix) Gap your plugs .040 - .050. [/quote] I swapped out to Pertronix, but didn't read any mention of changing the gap. Is this your experience to find it to run better with the .040-.050 setting? Thanks [/quote] (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:52 AM |
