I think I screwed up my rear wheel bearing install, again. :( Another $50 down the drain... |
3liter914-6 |
May 12 2004, 11:28 PM
Master of Clueless Posts Group: Benefactors Posts: 310 Joined: 12-October 03 From: State College, PA Member No.: 1,238 Region Association: MidAtlantic Region |
So I screwed up one of my bearings last night. The first one just slid right in smooth as glass. The second one went in a little cockeyed and wouldn't budge. Had to pound it out, one bearing down. So I went and got a new bearing this AM, and a few pounds of dry ice to cool it down super fast. A little persuasion with an appropriate drift and it was sunk home.
Put the trailing arm on the car, and fab'd up the PP tech article tool and started cranking it down. Well something went wrong, too small of a socket or too weak of a washer (it bent), and the hub ended up a little cockeyed in the bearing. Not too far in maybe 1cm. stuck fast, so seeing no other option, I tapped it out from the rear. I just want to make sure the bearing is screwed, right? The seal popped off a little bit and I can see the balls in on the race. I can't think of any actual bearing bits that I damaged, but if the seal has popped out, that's pretty much it for the bearing, right? If I weren't going to take the car anywhere, I guess I'd just try and reseat the seal and see where the chips fall, but I don't want to replace any bearings on the road, so I'm best off replacing it rather than trying to reseal it, right? Thanks, Adam |
Jeffs9146 |
May 13 2004, 02:36 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE So I screwed up one of my bearings last night. The first one just slid right in smooth as glass. The second one went in a little cockeyed and wouldn't budge. Had to pound it out, one bearing down. So, I had the same problem when I was assembling mine!! There was a small sharper edge on the hub that kept it from sliding in strait! I ended up softening the lip with a dremmel and it slid in like butter! Live and learn, if it looks crooked----it probably is!! Jeff |
Lo-Fi Version | Time is now: 16th June 2024 - 07:56 AM |
