> Its Suspension Time!, anyone with tips tricks?
cha914
post Jan 14 2003, 11:52 AM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus
Starting friday I will be pulling the suspension off the 914 and
- installing Koni sports all around with the fully adj perches in the rear
-new poly bushings all around (from weltmeister...street compound)
-turbo tie rod kit
-new ball joints
...anyway...this is the last part of the 914 that I haven't pulled off the car yet, so its time. any, tips, hints that you have will be much appreciated. I am going to be doing this with the help of a lift and plenty of tools...so I am hoping to knock this out over the weekend...doable?
Thanks,
Tony
cha914
post Jan 14 2003, 04:56 PM
ok...thats good info...I will plan on at least double your time since its my first try.
Brad...you also mentioned earlier how you cut groves into the poly bushings to hold the grease...you got any pics of this?
Thanks for the help,
Tony
cha914   Its Suspension Time!   Jan 14 2003, 11:52 AM
Bleyseng   Brad is having a class this saturday on front susp...   Jan 14 2003, 02:24 PM
J P Stein   Are those gas shox? If not, the fronts are a stink...   Jan 14 2003, 02:32 PM
cha914   Unfortunately the drive to CA and back from TX wou...   Jan 14 2003, 03:06 PM
Jeroen   How the fuck do you get the friggin struts off the...   Jan 14 2003, 03:37 PM
bhfast   ball joint seperator it looks like a big fork, but...   Jan 14 2003, 03:48 PM
bhfast   local auto parts store should have it for around ...   Jan 14 2003, 03:49 PM
J P Stein   I didn't mean to sound rude. I take a much mor...   Jan 14 2003, 03:52 PM
Jeroen   I got that one... won't work on the strut/ball...   Jan 14 2003, 03:53 PM
bhfast   when i did mine it didjn't work either, so i u...   Jan 14 2003, 03:58 PM
Brad Roberts   Here is how to get the ball joint out of the strut...   Jan 14 2003, 04:31 PM
cha914   I didn't take anything as rude...just want to ...   Jan 14 2003, 04:33 PM
Bleyseng   Yeah, the ball joints get rusted in place to the s...   Jan 14 2003, 04:37 PM
Brad Roberts   Tony. With proper tools.. I takes me 8 hours to c...   Jan 14 2003, 04:38 PM
Brad Roberts   I dont use heat.. ever. Your lower ball joints don...   Jan 14 2003, 04:40 PM
cha914   ok...thats good info...I will plan on at least dou...   Jan 14 2003, 04:56 PM
Bleyseng   Well if you use too friggin much heat! Just a ...   Jan 14 2003, 05:14 PM
Brad Roberts   I tried to take pics of it... but none of them tur...   Jan 14 2003, 05:24 PM
cha914   Ok...I have a little dremel... how deep of a cut....   Jan 14 2003, 05:30 PM
Brad Roberts   Umm.. half the thickness of a No.2 Pencil (the yel...   Jan 14 2003, 05:33 PM
cha914   sorry, I got confused...when you said thickness, I...   Jan 14 2003, 05:55 PM
Mueller   Back in the old days when I ran poly bushings inst...   Jan 14 2003, 06:12 PM
Bleyseng   Nice pic! Thanks, you sell those too?? Geoff :...   Jan 14 2003, 07:41 PM
Brad Roberts   Mike would whore his ass out if he had too. :sho...   Jan 14 2003, 07:44 PM
cha914   hang in there mike...maybe in a year I will be giv...   Jan 14 2003, 09:13 PM
Gint   This is what it looks like when you get it all out...   Jan 14 2003, 11:08 PM
cha914   That looks real nice ginter...but mine are going t...   Jan 15 2003, 12:21 AM
Jeroen   wow! nice clean up! did you have all that ...   Jan 15 2003, 02:57 AM
Gint   I bead blasted it and powder coated it all right i...   Jan 15 2003, 10:32 AM
gklinger
- Lo-Fi Version Time is now: 25th November 2026 - 10:52 PM
