SOLD |
SOLD |
orange914 |
Feb 17 2012, 05:19 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Valy |
Feb 17 2012, 05:53 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Ever want to add oil pressure gauge, keep your dummy light AND not have to locate and change the leak prone taco plate and find the proper matched s/u? Got that covered This is an O.E. VW VDO black ring 5 bar gauge with the matched combination sending unit that operates both the dummy light and gauge. The harness wiring is already between the dash and enginge bay so all you have to do is install with a extention and tee into dummy light oil port. I can get pictures but may be a few days 1st $80 (shipped) (IMG:style_emoticons/default/driving.gif) How exactly do you install the pressure sensor on the taco plate? Where is that oil pressure harness located? |
bdstone914 |
Feb 17 2012, 06:47 PM
bdstone914 Group: Members Posts: 4,533 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Where is that oil pressure harness located? [/quote] You can nto install a pressure sender on a taco plate. It is for oil temp. No oil pressure in the sump of the case. The oil pressure sender port is on the top of the engine. Most people install the sender remote mounted using a flexible brake line. Using a Tee on the oil pressure sender is not a good idea. The vibration of the engine will break it off at the threads and you have an oil gyser on top the engine. I hope that unit is new as that is about the retail price. Bruce |
orange914 |
Feb 17 2012, 07:15 PM
Ever want to add oil pressure gauge, keep your dummy light AND not have to locate and change the leak prone taco plate and find the proper matched s/u? Got that covered This is an O.E. VW VDO black ring 5 bar gauge with the matched combination sending unit that operates both the dummy light and gauge. The harness wiring is already between the dash and enginge bay so all you have to do is install with a extention and tee into dummy light oil port. I can get pictures but may be a few days 1st $80 (shipped) (IMG:style_emoticons/default/driving.gif) How exactly do you install the pressure sensor on the taco plate? Where is that oil pressure harness located? Sorry, I guess I wasn't clear. This set up you Do not have to deal with the usual leak prone taco plate -it's the round plate under the engine-. The combination pressure sender is teed in to the oil galley tap on the top side where the little single oil dummy light is already in. Much easier install. The stock harness on my 73' had a existing wire for the optional oil pressure gauge. It runs the interior stretch from the engine bay to the dash area, it was factory ready to plug in if you opted the gauge. I forget the wire color or exact location but I'm sure someone here knows it's color and location of the top. Imput on color/location anyone??? I hope that unit is new as that is about the retail price. no not new, from what ebay search I've done it showed the VDO combo. sender ran around $80, thats new of course and/but priced with out the gauge. I'm open for an offer. O.B.O. Thanks for the input, not trying to get rich just clear out some good used parts. Mike |
bdstone914 |
Feb 17 2012, 11:26 PM
The senders are only about $30 new.
http://www.jegs.com/i/VDO/918/360006/10002...roductId=887192 Ebay is no guide as to real value. |
orange914 |
Feb 18 2012, 12:51 AM
Alright already Bruce. Make an offer, whittle me down if your interested, I'll probably take it. Many times original matched parts are preferred P.M. me if your interested like I said earlier I'm negotiable. No need for a 3rd scorging (IMG:style_emoticons/default/shades.gif) Mike |
bdstone914 |
Feb 18 2012, 07:55 AM
Alright already Bruce. Make an offer, whittle me down if your interested, I'll probably take it. Many times original matched parts are preferred P.M. me if your interested like I said earlier I'm negotiable. No need for a 3rd scorging (IMG:style_emoticons/default/shades.gif) Mike I am not trying to get on your case or run you down. I am sure you are honest in your intentions but have put out some incorrect and bad information. I am not interested in the part but do not want to see another member get a bad dea or follow poor advise. A tee should NEVER NEVER be used on an oil pressure unit. It can lead to it breaking at the threads. With the unit positioned on top the engine it will break from the constant vibration. This can lead to losing the engine oil, engine damage and possible fire. I have seen them break. A picture would help you sale. If you do not have it I will give you or the buyer the correct plug harness for the back of the gauge. Bruce , |
Lo-Fi Version | Time is now: 3rd June 2024 - 12:41 AM |
