Installing new Rubber Engine Compartment Seals, What to lubricate them with |
euro911 |
Jan 12 2012, 11:30 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Since the drive train is out and Milt fixed the engine shelf in my '75, I'm getting ready to install new [914rubber.com] seals around the engine compartment.
The old ones were hard and brittle (what was left of them), and I had to bend the rails on the slots apart a little to get them out. What do you guys use to lubricate new seals so they don't bind or tear when pulling them in? (IMG:style_emoticons/default/popcorn[1].gif) |
CT914 |
Feb 20 2012, 02:26 PM
Newbie Group: Members Posts: 1 Joined: 20-February 12 From: New England Member No.: 14,148 Region Association: North East States |
Hello,
I have a similar problem, having to replace the engine tray shelf, right side due to dreaded battery rust. So we cut/ground the old one out and before we installed the new one, went to put the rubber on and it doesn't fit. The new one has a track of .200" while the old one had a track .400". After trying to slide it on we tried to insert one lip and press the other one in. The old track wasn't a problem due to the larger width. Is there any way to insert the old seals into the new shelf? |
Black22 |
Feb 20 2012, 06:23 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
Hello, I have a similar problem, having to replace the engine tray shelf, right side due to dreaded battery rust. So we cut/ground the old one out and before we installed the new one, went to put the rubber on and it doesn't fit. The new one has a track of .200" while the old one had a track .400". After trying to slide it on we tried to insert one lip and press the other one in. The old track wasn't a problem due to the larger width. Is there any way to insert the old seals into the new shelf? I had the same problem. I had to open the channel up (very carefully) with a wide screw driver. If you do it nicely, once the seals are in place you 'll never notice. (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 10:19 AM |
