H4 headlights, which bulbs and how much wattage? |
rwilner |
Feb 22 2012, 10:33 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
I replaced the tungsten sealed-beams with the Hella H4s that take bulbs. The bulbs that came with the lenses aren't too impressive.
What are the best bulbs (and wattage) people run with these lenses using stock wiring and relays? |
RickS |
Feb 23 2012, 12:45 AM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Reading on the pelican site, it appears you will only get low beam...
http://www.danielsternlighting.com/tech/bu...onversions.html Think I will go with 85/100 h4 bulbs and relays. Everything I read about HID in a non-HID lamp is bad news. |
rwilner |
Feb 23 2012, 09:58 AM
Reading on the pelican site, it appears you will only get low beam... They sell a dual-filament kit that gives you both high and low beam. This will retrofit into H4 lenses, which are purchased separately from the kit. The lens/HID package is around $300. QUOTE Think I will go with 85/100 h4 bulbs and relays. me too. do you have a relay selected and a source? is a kit available? |
RickS |
Feb 23 2012, 10:27 AM
Reading on the pelican site, it appears you will only get low beam... They sell a dual-filament kit that gives you both high and low beam. This will retrofit into H4 lenses, which are purchased separately from the kit. The lens/HID package is around $300. QUOTE Think I will go with 85/100 h4 bulbs and relays. me too. do you have a relay selected and a source? is a kit available? I am thinking this can be probably be modified to work: http://www.pelicanparts.com/cgi-bin/smart/...%2D%38%39%29%20 |
Lo-Fi Version | Time is now: 8th June 2024 - 04:19 PM |
