How to try to turn over a 1.7 |
wndsnd |
Feb 24 2012, 02:56 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Just got the 73 home and I want to see if the engine is siezed. What is the best way to do this. Can I get a socket on the fan, or should I put it in 2nd or 3rd gear and try to roll it? What size is the Fan Hex Nut?
Thanks Again (IMG:style_emoticons/default/smile.gif) |
Cap'n Krusty |
Feb 24 2012, 04:37 PM
The center bolt holding the fan hub on is an 8mm x 1.25, and takes a 13mm wrench. Might be a really bad idea to use that, even if the plugs are out. Breaking it would be a definite downer.
Take the spark plugs out and remove the point wire from the coil if you're gonna try to crank it with the starter. The Cap'n |
wndsnd |
Feb 24 2012, 04:44 PM
The center bolt holding the fan hub on is an 8mm x 1.25, and takes a 13mm wrench. Might be a really bad idea to use that, even if the plugs are out. Breaking it would be a definite downer. Take the spark plugs out and remove the point wire from the coil if you're gonna try to crank it with the starter. The Cap'n If I hit it with the starter and the engine is frozen, what damage will I do! (IMG:style_emoticons/default/unsure.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 09:20 AM |
