rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,304 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
After installing a new clutch which included installing a new flywheel, a new pilot bearing and a new throwout bearing, I am getting a high pitch whining noise in 5th gear @ 2900-3500 RPMs. It also happens a little in 4th at higher RPMs, but it's in 5th gear where it's really noticable. It goes away immediately when I depress the clutch pedal. It's not the same noise that the old throwout bearing made which caused me to replace the clutch in the first place.
It's not crazy loud, but loud enough to be slightly annoying.I never heard the sound before I replaced the clutch. But then again, I had a bad rear wheel bearing that I replaced with the clutch that might have been drowning it out before. I was thinking it might be some sort of sympathetic vibration, but then I would expect the noise to happen at the same RPMs regardless of what gear I'm in, but it doesn't happen in 1st, 2nd or 3rd and barely in 4th. Car drives and shifts fine. (no better or worse than it has for the 7 years I've owned it) Thoughts? |
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
It goes away immediately when I depress the clutch pedal. ... it doesn't happen in 1st, 2nd or 3rd and barely in 4th. Silly preliminary question: You did put fluid in it right? Now that that question is out of the way... 1. If you don't depress the clutch and simply decelerate while in 4th, and especially in 5th gear, does it go away or change in any way? 2. When you shift from 4th to 5th does the whine restart and just get louder as you go faster? 3. Is it the same pitch (frequency) the whole time or does it get higher? 4. While in 5th gear, is it the same volume all the time, or does the volume increase with higher speed? 5. While in either 5th and going at a constant speed, will it increase in volume with more acceleration? Good luck |
rjames |
The weather was finally dry enough the other day where I could take the car out to answer the questions that were asked a while back:
Silly preliminary question: You did put fluid in it right? Now that that question is out of the way... Checked fluid level was full 1. If you don't depress the clutch and simply decelerate while in 4th, and especially in 5th gear, does it go away or change in any way? Noise goes away 2. When you shift from 4th to 5th does the whine restart and just get louder as you go faster? Yes up to ~ 70mph then above 70 it goes away. 3. Is it the same pitch (frequency) the whole time or does it get higher? Gets higher 4. While in 5th gear, is it the same volume all the time, or does the volume increase with higher speed? Pitch egs higher, volume doesn't change too much. Happens only in the ~55mh-70mpg range. 5. While in either 5th and going at a constant speed, will it increase in volume with more acceleration? Mostly just increases in pitch So if it's the bearing is this something that I have to address any time soon? I don't to trash my transmission for lack of replacing a bearing, but I can live with the noise for a while if it's not going to hurt anything. |
Lo-Fi Version | Time is now: 4th July 2025 - 06:24 AM |
