oil lines for remote cooler |
lmcchesney |
May 15 2004, 07:21 PM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
I have a remote oil cooler, and i was wondering what type of lines i can use to carry the oil to and from the cooler. Understandably they must be able to resist extremely high temperatures, and able to resist any corrosive properties of the oil.
Also, would transmission lines be a good solution? |
campbellcj |
May 15 2004, 08:10 PM
I can't Re Member Group: Members Posts: 4,545 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
If you do a search here for "oil cooler", you will find more than you ever wanted to know (IMG:style_emoticons/default/wink.gif)
The braided AN lines are usually viewed as the "best" due to their strength and heat-resistance (and good looks too), but are not cheap. You can easily spend a few $hundred just on the hose and AN fittings. Most guys use either -10, -12, or -16 sizes depending on the specific application (engine type/size and driving conditions.) The non stainless-sheathed oil lines (usually blue) are another option, but personally I would be reluctant to use hose-barb type fittings if it were my engine at stake. Spring for the good socket-style threaded AN stuff. |
Lo-Fi Version | Time is now: 22nd May 2024 - 10:01 PM |
