Weber IDA 3C Bookends? Seized Shafts |
mr914 |
Mar 4 2012, 03:46 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
Picked up a 75 914-6 that has been sitting way too long at a body shop 8-10 years. As if I need another project like a hole in the head.
The body shop went bankrupt and the car went thru a couple of hands.... It has a laundry list of problems, including flintstone brakes, disassembled and seized webers. I picked it up for a really good price about the price of a factory oil tank. I'll cover the car in a different tread. The IDA3C shafts are seized on both carbs. I've pulled the carbs and manifolds to clean them up and have a few questions. 1) What is the best way to separate the manifolds from the carbs. I've removed the bolts and tried gently tapping on the manifold to break them loose. 2) Is there any hope/tricks for un-seizing the throttle shafts? Would immersion ultrasonic cleaning have any chance in freeing them? Thanks for your input |
mr914 |
Mar 6 2012, 09:03 PM
For now, I think I'll soak the carbs,clean them up and put them on the shelf.
I need to move on to looking at the other issues with this project car. Still have to address the flintstone brakes and the motor. If the motor is toast, I'll put it on the shelf and look for a 3.0 or 3.2 with FI. Refer to previous post with water in cylinder head If the motor has compression and rotates freely, then I can go back to the carbs to see if I can get it to fire. This could be a perpetual project.... |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:38 AM |
