2.0 going into 73, Vacuum and fuel |
glens67 |
Mar 8 2012, 02:02 PM
Newbie Group: Members Posts: 35 Joined: 13-March 10 From: Middleton, ID Member No.: 11,462 Region Association: Rocky Mountains |
I'm pulling the 1.7 out of my 1973, Will be installing a 1975 2.0. The 75 I Pulled the 2.0 out of had the fuel pump located in the front position under the fuel tank. The fuel pump looks like this
(IMG:http://www.914world.com/bbs2/uploads_offsite/i166.photobucket.com-11462-1331236941.1.jpg) The fuel pump that was in the 73 was located in the rear trunk. with the fuel lines running through the latch cup. I know that I will need to cut an access hole to mount the fuel pump in the fuel tank area. The pump looks like this. (IMG:http://www.914world.com/bbs2/uploads_offsite/i166.photobucket.com-11462-1331236941.2.jpg) I would like to mount the fuel pump In the 1975's location. How do I get the pump wiring moved to the front in the 1973? Which pump would be the best one to use? Also who has the best vacuum hose kit for the 2.0 FI set up? I will be renewing all fuel lines except the tunnel lines, they were already replaced. Thanks Glen |
Lo-Fi Version | Time is now: 11th June 2024 - 12:03 AM |
