phillstek |
Member ![]() ![]() Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None ![]() |
The car has been sitting around for 12 years and the engine was only cranked for the first time a few month or so ago to see if it would run. Squirted some oil into the jugs, cleaned the Webers etc and she fired up pretty much on the 3rd attempt.
Proceeded with other major repairs and mods on the basis that the 2.4 was going to ok. Fast forward to now. After completing all the other items that needed doing, it's time to tune her up. Start it up and get it running but after about twenty minutes it's still belching blue smoke. I suspect I have a stuck ring or two. My brother suggests we run some flushing oil in it and find a few good long hills and load the combustion chambers to max pressure to see if that will free them up. I'm not so sure. A bit of back story. Engine was rebuilt and had maybe 10k miles on it before putting away. I did not drain oil at the time (Mobil 1 full synth). The other thing is, I also have 3.0 cis that I purchased from a world member last year when we were over in the US. It was running in a 911 that we got to drive and checked out fine. Leakdown and compression tests confirm that it should be good to go. This engine was purchased as a back up plan should I have issues with 2.4. Rewind a month or so, decided that I wanted to stick with 2.4 and shelve 3.0 for now with view to build a killer 3.4 out of it at a later date. Now I don't really know what the best path would be. Do I try flushing oil in 2.4, possibly breaking a ring? Do I pull engine and replace rings only? Should drop 2.4 and put in 3.0 thereby shelving 3.4 killer engine? If I put 3.0 in do I keep CIS or put my Webers on it? If I put 3.0 in for time being should I rebuild 2.4 then? Thanks, phil |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
new pistons and cylinders cost 2K...
I'd open it up before I took a gamble that I wouldn't break the ring.... if its been rebuilt and the P's/C's are in spec why risk trashing them...... |
Lo-Fi Version | Time is now: 10th June 2024 - 08:19 AM |
