Best Practices of Gas Tank restoration, Little Rust in the bottom |
Aaron Cox |
Mar 19 2012, 11:52 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
Newb question (IMG:style_emoticons/default/av-943.gif)
Whats the best practices of gas tank resto? Pulled the tank, and the bottom has plenty of rust, but not really flaking. Ideas? You experiences? Heard muriatic(Sp?) acid + a bit of water for a few days does wonders.... |
Elliot Cannon |
Mar 19 2012, 12:39 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I took mine to a radiator shop and had it "boiled out" (whatever that means). There are products that you can use to then seal the tank. Hey? I thought you knew all this $hit? (IMG:style_emoticons/default/confused24.gif) Didn't you used to own one of these cars? (IMG:style_emoticons/default/av-943.gif)
Aaron Cox |
Mar 19 2012, 12:43 PM
I took mine to a radiator shop and had it "boiled out" (whatever that means). There are products that you can use to then seal the tank. Hey? I thought you knew all this $hit? (IMG:style_emoticons/default/confused24.gif) Didn't you used to own one of these cars? (IMG:style_emoticons/default/av-943.gif) Yuuuup.... never had to mess with the tank last 'build'. Idea's on cost elliot? |
Bob L. |
Mar 19 2012, 12:51 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
I took mine to a radiator shop and had it "boiled out" (whatever that means). There are products that you can use to then seal the tank. Hey? I thought you knew all this $hit? (IMG:style_emoticons/default/confused24.gif) Didn't you used to own one of these cars? (IMG:style_emoticons/default/av-943.gif) Yuuuup.... never had to mess with the tank last 'build'. Idea's on cost elliot? I brought mine to a local Rad. shop to be boiled out and coated on the inside. All for $200. Seems like a good deal to me, after looking at the time and PITA it is to do yourself. |
poorsche914 |
Mar 19 2012, 12:53 PM
T4 Supercharged Group: Members Posts: 3,091 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
A radiator shop here in east TN quoted me $135 to clean and treat. So looks like there is quite a range as far as pricing.
(IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 02:12 AM |
