Spring Enduro, In Medford |
Randal |
Jan 22 2012, 03:05 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
I couldn't find the sign up PDF for the Enduro on the website ( http://ssccmedford.org/default.aspx ) but did get it by email.
So if you want the entry form PM me with your email address and I'll foward the PDF to you. Great event. |
J P Stein |
Mar 22 2012, 08:04 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Had a couple inches of snow here last night. Other than that the weather is great. (IMG:style_emoticons/default/rolleyes.gif)
Randal |
Mar 22 2012, 10:13 AM
Had a couple inches of snow here last night. Other than that the weather is great. (IMG:style_emoticons/default/rolleyes.gif) Checked the 10 day forecast and it doesn't look all that good. Cold and rain. We run at the Marina in the cold all the time, but wet isn't much fun in my car. As much as I'd like to run the event, got to admit that I'm a bit on the fence concerning the weather. |
Randal |
Mar 23 2012, 05:20 PM
Had a couple inches of snow here last night. Other than that the weather is great. (IMG:style_emoticons/default/rolleyes.gif) Checked the 10 day forecast and it doesn't look all that good. Cold and rain. We run at the Marina in the cold all the time, but wet isn't much fun in my car. As much as I'd like to run the event, got to admit that I'm a bit on the fence concerning the weather. My level of interest peaked today when I got two great take off from John Berget. Thank you John! Looks like I will buy couple of new canti's from Brandon at Roger Kraus, so will have good rubber all around. Not Avons, but we'll save that speed trick for later. Hey maybe it will clear up enough on Sunday to run the event. (IMG:style_emoticons/default/smile.gif) |
grantsfo |
Mar 23 2012, 10:08 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Had a couple inches of snow here last night. Other than that the weather is great. (IMG:style_emoticons/default/rolleyes.gif) Checked the 10 day forecast and it doesn't look all that good. Cold and rain. We run at the Marina in the cold all the time, but wet isn't much fun in my car. As much as I'd like to run the event, got to admit that I'm a bit on the fence concerning the weather. My level of interest peaked today when I got two great take off from John Berget. Thank you John! Looks like I will buy couple of new canti's from Brandon at Roger Kraus, so will have good rubber all around. Not Avons, but we'll save that speed trick for later. Hey maybe it will clear up enough on Sunday to run the event. (IMG:style_emoticons/default/smile.gif) You're better off with cantis as you will need to completely change suspension setup with Avons and that will take time to work out. |
Randal |
Mar 23 2012, 10:14 PM
Had a couple inches of snow here last night. Other than that the weather is great. (IMG:style_emoticons/default/rolleyes.gif) Checked the 10 day forecast and it doesn't look all that good. Cold and rain. We run at the Marina in the cold all the time, but wet isn't much fun in my car. As much as I'd like to run the event, got to admit that I'm a bit on the fence concerning the weather. My level of interest peaked today when I got two great take off from John Berget. Thank you John! Looks like I will buy couple of new canti's from Brandon at Roger Kraus, so will have good rubber all around. Not Avons, but we'll save that speed trick for later. Hey maybe it will clear up enough on Sunday to run the event. (IMG:style_emoticons/default/smile.gif) You're better off with cantis as you will need to completely change suspension setup with Avons and that will take time to work out. Switching to Avon's is an expensive deal. New tires and wheels, say about $3,000 minimum. Actually the Avon's don't require that much suspension readjustment, given they are bias ply, unlike A6's which require an entirely different set up. It'd be nice to have a nice soft compound with the right sized wheels and tires, again based upon arithmetic from the existing weight balance. All in all it'll be worth some time. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 03:50 AM |
