> 750mV from battery to ground, Tracing the short: any usual suspects?
Prospectfarms
post Mar 27 2012, 06:32 AM
Key off. Red terminal to body gives somewhere between 1V and 750mV. (IMG:style_emoticons/default/sad.gif) To me that seems like a bare wire short to ground but I'm not an expert.
Likely spots? Anyplace I could test first before tracing the whole electrical system?
How about a short (N.P.I.) list of always-hot wires in the car. Doesn't have to be comprehensive -- just looking for a starting point.
Thanks.
Spoke
post Mar 27 2012, 01:01 PM
Jerry
Here's some basic voltages to check.
1) Measure battery voltage (on each battery terminal, not clamp)
2) Measure battery positive terminal (not clamp), to chassis ground.
3) Measure battery negative terminal (not clamp), to chassis ground.
Let me know what you find.
Prospectfarms   750mV from battery to ground   Mar 27 2012, 06:32 AM
stugray   What? Does the car run? You should have ~12-13 Vo...   Mar 27 2012, 08:25 AM
Prospectfarms   What? Does the car run? You should have ~12-13 V...   Mar 27 2012, 08:49 PM
ape914   What? Does the car run? You should have ~12-13 ...   Mar 27 2012, 09:28 PM
Valy   What? Does the car run? You should have ~12-13 ...   Mar 27 2012, 09:36 PM
Prospectfarms   [quote name='Prospectfarms' post='1655151' date='...   Mar 27 2012, 09:51 PM
Valy   1St, your battery is dead. Disconnect it and measu...   Mar 27 2012, 10:36 AM
Prospectfarms   1St, your battery is dead. Disconnect it and meas...   Mar 27 2012, 08:53 PM
underthetire   To check ghost drains Remove red wire from batter...   Mar 27 2012, 11:36 AM
Prospectfarms   To check ghost drains Remove red wire from batte...   Mar 27 2012, 08:57 PM
Spoke   Here's some basic voltages to check. 1) Measu...   Mar 27 2012, 01:01 PM
Prospectfarms   Here's some basic voltages to check. 1) Meas...   Mar 27 2012, 08:59 PM
Prospectfarms   If I understand what your saying, if there was onl...   Mar 27 2012, 09:40 PM
kg6dxn   The voltage you are reading could be capacitance f...   Mar 27 2012, 10:00 PM
Prospectfarms   The voltage you are reading could be capacitance ...   Mar 27 2012, 10:32 PM
rhodyguy   try taking the inline fuse for the stereo out and ...   Mar 28 2012, 11:18 AM
kg6dxn   You want to measure amperage. You want to see less...   Mar 28 2012, 05:18 PM
Prospectfarms   Dugout my real mulitmeter. Replaced fuse and batte...   Mar 28 2012, 07:26 PM
Valy   You are good although 25mA for the stereo is a bit...   Mar 28 2012, 08:32 PM
Prospectfarms   You are good although 25mA for the stereo is a bi...   Mar 29 2012, 05:48 AM
Valy   What else is always on? Clock?   Mar 29 2012, 08:43 AM
warrenoliver   What else is always on? Clock? when I had batt...   Mar 29 2012, 11:20 AM
Prospectfarms   Sorry for the delay responding. Unfortunately I do...   Mar 29 2012, 10:36 PM
kg6dxn   Your drain seems a little high with no radio or cl...   Mar 29 2012, 10:47 PM
Prospectfarms   Your drain seems a little high with no radio or c...   Mar 30 2012, 09:34 PM
- Lo-Fi Version Time is now: 11th November 2026 - 03:42 AM
