| Prospectfarms |
Mar 27 2012, 06:32 AM
Member ![]() ![]() Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest |
Key off. Red terminal to body gives somewhere between 1V and 750mV. (IMG:style_emoticons/default/sad.gif) To me that seems like a bare wire short to ground but I'm not an expert.
Likely spots? Anyplace I could test first before tracing the whole electrical system? How about a short (N.P.I.) list of always-hot wires in the car. Doesn't have to be comprehensive -- just looking for a starting point. Thanks. |
| rhodyguy |
Mar 28 2012, 11:18 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
try taking the inline fuse for the stereo out and a measure again. any other electronic stuff other than stock that would require?
Prospectfarms 750mV from battery to ground Mar 27 2012, 06:32 AM
stugray What?
Does the car run?
You should have ~12-13 Vo... Mar 27 2012, 08:25 AM
Prospectfarms
What?
Does the car run?
You should have ~12-13 V... Mar 27 2012, 08:49 PM
ape914
What?
Does the car run?
You should have ~12-13 ... Mar 27 2012, 09:28 PM
Valy
What?
Does the car run?
You should have ~12-13 ... Mar 27 2012, 09:36 PM
Prospectfarms
[quote name='Prospectfarms' post='1655151' date='... Mar 27 2012, 09:51 PM
Valy 1St, your battery is dead.
Disconnect it and measu... Mar 27 2012, 10:36 AM
Prospectfarms
Disconnect it and meas... Mar 27 2012, 08:53 PM
underthetire To check ghost drains
Remove red wire from batter... Mar 27 2012, 11:36 AM
Prospectfarms
Remove red wire from batte... Mar 27 2012, 08:57 PM
Spoke Here's some basic voltages to check.
1) Measu... Mar 27 2012, 01:01 PM
Prospectfarms
1) Meas... Mar 27 2012, 08:59 PM
Prospectfarms If I understand what your saying, if there was onl... Mar 27 2012, 09:40 PM
kg6dxn The voltage you are reading could be capacitance f... Mar 27 2012, 10:00 PM
Prospectfarms
The voltage you are reading could be capacitance ... Mar 27 2012, 10:32 PM
kg6dxn You want to measure amperage. You want to see less... Mar 28 2012, 05:18 PM
Prospectfarms Dugout my real mulitmeter. Replaced fuse and batte... Mar 28 2012, 07:26 PM
Valy You are good although 25mA for the stereo is a bit... Mar 28 2012, 08:32 PM
Prospectfarms
You are good although 25mA for the stereo is a bi... Mar 29 2012, 05:48 AM
Valy What else is always on? Clock? Mar 29 2012, 08:43 AM
warrenoliver
when I had batt... Mar 29 2012, 11:20 AM
Prospectfarms Sorry for the delay responding. Unfortunately I do... Mar 29 2012, 10:36 PM
kg6dxn Your drain seems a little high with no radio or cl... Mar 29 2012, 10:47 PM
Prospectfarms
Your drain seems a little high with no radio or c... Mar 30 2012, 09:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th November 2026 - 03:42 AM |
