> Panel stiffness, Door metal thickness
porschefile2010
post Mar 28 2012, 01:12 AM
Region Association: Australia and New Zealand
I wouldn't mind some input from the USA if possible.
Down here in NZ 914's are a rarety and my 75 2.0 is the only one I have really been close to and there are no others handy to check out.
I am bare metalling the car to go back to original- so paint strip, rust kill, etch prime etc.
I have noticed when I have been scraping the paint off the panels ( it's had three repaints)that the door panels have a hell of a lot of flex. The rear guards have a small amount, the fronts not too bad, but the doors! Are they all like this. There doesn't seem to be any side bars inside and they flex probably as much as 1/4 inch in the softest patches.
The doors are absolutely rust free and original paint right back to the first coats so it doesn't look like there has been any bodgy repairs.
So, question is this normal and if so filling and fairing must be tricky as it seems a difficult job bogging a flexi surface and then boarding it down to a fair surface?
Thanks
porschefile2010
post Mar 29 2012, 02:37 AM
Oh Dear! Had another look this evening and there are two panel stiffeners each side about half way up. Maybe they have become detached at the welds in an accident and aren't doing the job. I will take a closer look tomorrow. Thanks anyway.
Tom_T
post Mar 29 2012, 07:20 AM
TMI....
QUOTE(porschefile2010 @ Mar 29 2012, 01:37 AM) *
Richard,
That's about the right position in the upper 1/3 or 1/2 of the door, since they're not really panel stiffeners - but side impact protection for driver & passenger, so placed appropriately for maximum accident protection.
In fact, if I recall there is about a 1/4" space between the skin panel & bar - except where welded at the ends. So you won't get much - if any - stiffening of the outer skins from them.
And since the body panels on 914s are so flat & smooth - lacking the body creases/folds & formed panel curvatures that you see in most modern cars today to stiffen the even thinner sheet metal - they have always had a good deal of flex. Even the curves of the more rounded 911/912 & Bugs/Ghias of the day gave them more bend resistant panels, but their flat areas are also susceptible to flex like the panels on 914s.
No worries on those doors! (IMG:style_emoticons/default/biggrin.gif)
... just hope that the rust & bondo are minimal! (IMG:style_emoticons/default/dry.gif)
Cheers! (IMG:style_emoticons/default/beerchug.gif)
Tom
porschefile2010   Panel stiffness   Mar 28 2012, 01:12 AM
Tom_T   Yes, the relatively flat & thin panel skins we...   Mar 28 2012, 01:28 AM
porschefile2010   Thanks Tom. That's really helpful to know. The...   Mar 28 2012, 02:35 AM
Tom_T   Thanks Tom. That's really helpful to know. Th...   Mar 28 2012, 01:19 PM
Tom_T   PS - a small magnet run over the painted surface i...   Mar 28 2012, 01:20 PM
Dave_Darling   Early on in the 73 model year, all of the doors go...   Mar 28 2012, 02:47 PM
Tom_T   Early on in the 73 model year, all of the doors g...   Mar 28 2012, 02:56 PM
porschefile2010   Interesting. There are definately no side beams an...   Mar 28 2012, 08:06 PM
porschefile2010   Oh Dear! Had another look this evening and the...   Mar 29 2012, 02:37 AM
Tom_T   Oh Dear! Had another look this evening and th...   Mar 29 2012, 07:20 AM
rick 918-S   Not sure but most cars with side beams had some la...   Mar 29 2012, 08:33 AM
ruby914   If I may expand on your topic... I just did my fir...   Mar 29 2012, 10:48 AM
ThePaintedMan   Also what is a good way to get that tar off the ...   Mar 29 2012, 11:24 AM
porschefile2010   I would be careful glassing the inside unless you ...   Mar 29 2012, 11:46 AM
Tom_T   I would be careful glassing the inside unless you...   Mar 30 2012, 10:22 AM
ruby914   My doors don't have the beams so glass is easy...   Mar 29 2012, 12:26 PM
porschefile2010   Well if you are sure your doors are in perfect sha...   Mar 29 2012, 12:44 PM
porschefile2010   I understand Tom, So would we have to take the fen...   Mar 30 2012, 12:57 PM
Tom_T   I understand Tom, So would we have to take the fe...   Mar 30 2012, 01:59 PM
rick 918-S   Post photos so we can see what your up against. :t...   Mar 30 2012, 02:02 PM
Tom_T   Post photos so we can see what your up against. :...   Mar 30 2012, 02:14 PM
rick 918-S   Post photos so we can see what your up against. ...   Mar 30 2012, 08:47 PM
porschefile2010   I'll try tonight   Mar 30 2012, 02:42 PM
porschefile2010   Sorry, these aren't great shots. On the RHS t...   Mar 30 2012, 10:02 PM
porschefile2010   Bump?   Mar 31 2012, 05:35 PM
rick 918-S   Very poor photos but I think I get what your doing...   Mar 31 2012, 09:24 PM
porschefile2010   Thanks Rick. I will take a look at the problem fro...   Mar 31 2012, 10:16 PM
- Lo-Fi Version Time is now: 7th March 2026 - 07:41 AM
